Introduction: Tic-tac Container Into Sharpener
This is a fast and inexpensive way to have a covered sharpener.
The things you need are:
- a small sharpener
- tic-tac's (any kind)
- superglue
Step 1: Empty the Container
To empty the container you just go from the lid end and pull up! If you would like, you can leave the label on.
Step 2: Glue the Sharpener
To glue the sharpener, all you have to do is turn the sharpener so that the hole is facing up. Just make sure that it's on the side that has the hole in the lid. Glue the top of each side and the bottom of each side to the container.
Step 3: You're All Done
All you have to do is hold it for a few minutes to set the glue. Then you have a covered sharpener.
If you'd like ... you can also decorate it however you want!
Dorm Hacks Contest 2016
