Introduction: Top Eight Interesting Notepad Tricks
About: I love to design new things and make products. i do design things in fusion 360 and love 3d printing. i have a keen interest in robotics and automation on a major. i constantly do research and learn about new …
Notepad is the most basic software which is found in the Windows Operating System. It can be used to read and write text file. But do you know this piece of software can do a lot more than just a text writing.
So , In this Instructable I will show Ten Interesting Notepad Tricks That You can try right now on your Computer
Check More at My blog Here : - http://hardiqv.blogspot.com/
Step 1: Create a Diary on a Notepad
This Notepad trick will allow you to create Notepad note in such a format that whenever you edit your note, it will get saved with date and time stamp automatically.
To do this, follow these steps:
  • Open Notepad
  • Type .LOG in first line.
  • Save the file as Log.txt
  • Now, write something to the file and it will automatically get saved with edited date and time.
Now you can create Diaries right in Your computer without any need of additional Software.
How Cool is That?
Step 2: Create Fake Windows Errors With Notepad
This is another very cool Notepad trick that allows you to create Fake error messages. You can create Fake error message with any message.
  • Open Notepad
  • Type X=Msgbox("Message Here",0+16,"Title Here")
  • Replace Message Here and Title Here with your Error Message and Error-Window Title respectively.
  • Save the file with error.vbs.
  • Now, click the file and you’ll get your custom-made Windows error message.
Step 3: Force Shutdown Your Windows
This trick will let you force shutdown your Windows in a single-click.If You don't want to go in start menu and waste a couple of seconds.
Follow These Steps:-
  • Open Notepad
  • Paste @echo off in first line.
  • Paste msg * Shutdown computer in second line.
  • Paste shutdown -c “Sleep Tight” -s in third line
  • Save the file with .BAT extension. For example, shutdown.bat
  • Click on your file and it will automatically shutdown your Windows.
Step 4: Create Password-protected Folder Using Notepad
Why to use any folder-locking software when your simple text editor, Notepad can lock your folders? To use this Notepad tricks. Follow these steps:-
  • Open Notepad
  • Copy the following code:
@ECHO OFF
title Folder Private
if EXIST "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" goto UNLOCK
if NOT EXIST Private goto MDLOCKER
:CONFIRM
echo Are you sure you want to lock the folder(Y/N)
set/p “cho=>”
if %cho%==Y goto LOCK
if %cho%==y goto LOCK
if %cho%==n goto END
if %cho%==N goto END
echo Invalid choice.
goto CONFIRM
:LOCK
ren Private "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
attrib +h +s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
echo Folder locked
goto End
:UNLOCK
echo Enter password to unlock folder
set/p "pass=>"
if NOT %pass%== HardiqV goto FAIL
attrib -h -s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
ren "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" Private
echo Folder Unlocked successfully
goto End
:FAIL
echo Invalid password
goto end
:MDLOCKER
md Private
echo Private created successfully
goto End
:End
  • HardiqV is password. Change it to your own password.
  • Save the file as private.bat with File Type As All Files (*.*).
  • Now, when you click private.bat, it will create a Private folder. Move your private files, documents and folders here.
  • Close Private folder.
  • Now, no one will be able to open the folder without the password.
Step 5: Make Computer to Speak Your Sentence
This Notepad trick will make computer to speak whatever you type in the provided text-box. To use this trick, follow these steps:
  • Open Notepad
  • Copy & paste this command:
  • Dim message, sapimessage=InputBox("What do you want me to say?","Speak to Me")Set sapi=CreateObject("sapi.spvoice")sapi.Speak message
  • Save the file as speak.vbs.
  • Double-click the file and it will open a prompt. Enter the sentence you want your computer to speak
  • Click OK and Notepad will speak the sentence for you.
Step 6: Make CD Drive Open & Close Again and Again
This notepad prank will make your CD drive open and close again and again continually. To use this notepad trick, use these following steps:
  • Open Notepad
  • Enter the following command:
Set oWMP = CreateObject(“WMPlayer.OCX.7”)
Set colCDROMs = oWMP.cdromCollection
do
if colCDROMs.Count >= 1 then
colCDROMs.Item(i).Eject
Next
For i = 0 to colCDROMs.Count – 1
Next
End If
wscript.sleep 5000
loop
  • Save your notepad file as cdopen.vbs
  • Now, open cdopen.vbs and it will start the process to continuously open and close CD drive
Step 7: Create Matrix Raining Code Screen
Have you watched the movie, “Matrix”? You might have seen a string of green characters appearing at the screen randomly. I am going to do something similar with the help of Notepad. To use this Notepad trick, follow these steps:
  • Open Notepad.
  • Type this command:
@echo off
color 02
:start
echo %random% %random% %random% %random% %random% %random% %random% %random% %random% %random%
goto start
  • Save the file as Matrix.bat
  • Click on Matrix.bat and the show begins.
Step 8: Make Your Keyboard LED Dance
Your keyboard has three LEDs above numpad of Scroll Lock, Caps Lock and Num Lock. This Notepad trick will make those three LED continually on and off, creating dancing effects. To do this, follow these steps:
  • Open Notepad
  • Enter following code
Set wshShell =wscript.CreateObject("WScript.Shell")
do
wscript.sleep 100
wshshell.sendkeys "{CAPSLOCK}"
wshshell.sendkeys "{NUMLOCK}"
wshshell.sendkeys "{SCROLLLOCK}"
loop
  • Save the file as Dance.vbs
  • Click the file and your all three LED lights will start dancing.
To stop, Shut down or Log off your PC.
Step 9: FINISH
I Hope You liked This Instructable
If So please Favorite it and considering voting me
Check More Here at : http://hardiqv.blogspot.com/
