Tornado Tubes
7,645
40
19
Introduction: Tornado Tubes
About: The name Cat’s Science Club comes from my daughter Aly, whom I call Aly Cat. She inspired me to take my love of science, and the fun I have with my students, to as many people as I can. Both my daughters hel...
We love making these tornadoes. The problem we come across is doing them cheaply. Sometimes we are making them for 24 or more kids in the classroom and the costs get beyond our means. When we are truly brave we add a bit of glitter and / or dish soap for some cool affects.
Teacher Notes
Step 1: Materials
You will need
2 Soda Pop or Water Bottles of the Same Size
Duct Tape
Step 2: Label Removel
Remove the label by adding hot water to the inside of the bottle. This helps melt the glue that holds the label on the bottle.
Step 3: Add Water
Add water to one of the bottles 3/4 of the way full.
Step 4: Prepare the Tape
Using dry hands tear off three pieces of tape that are about 4 inches long.
One piece needs to be torn into three equal parts.
The second piece of tape is torn in two equal parts.
The third piece of tape is left alone.
Step 5: Connect
Connect the two bottles by putting one on top of the other with openings placed on each other.
Using the thinner pieces (the ones cut into thirds), tape the bottle lips (openings) together. This is a good start to keep the bottles together. Use all three pieces.
It is much easier to have the thin pieces to start so they hold the bottles in place and don't slip when we apply more pressure with the thicker pieces.
Step 6: Another Layer
Add another layer of tape around the first three smaller tape pieces.
The 1/2 pieces are just the right size to go around the lip of the bottles without being interfered with by the collars.
Pull the tape around the connection as tight as possible. Repeat with second piece of tape.
Make sure to seal tape by applying pressure to the connection. We rubbed are hands around the connection several times.
Step 7: Last Layer
Add the last layer using the third piece of tape, the thickest of the three.
Take the last piece of tape and center it over the previous pieces. Wrap the tape tightly around the connection.
Make sure to cover the collar on both bottles.
Seal the tape by applying pressure all away around the tape where it touches the bottle.
Step 8: Test the Bottle
Test the bottle for leaks over a sink or outside.
We have made several of these with kids of varying ages and some are bound to leak. Don't want this leaking all over Momma Cat's kitchen or worse her carpet.
Step 9: Flip and Shake
Holding the bottles by their connection tightly (water in the bottom bottle), flip the bottles over so the water is now on top.
Shake the bottle in a circular motion. This will take some practice but it will get easier to do.
Step 10: Tornado!
As the water swirls around it will begin to create a vortex and what looks like a "tornado" will appear in the bottle!
Step 11: Did That Really Work?
With all the fake things on the internet, some may wonder if we used the tape or a store bought connector. We used the tape. Sorry our hand is in the way.
Also some maybe asking -weren't we looking at a smaller bottle earlier? Yes, yes you were. We switched over to the bigger bottles so that people could see the tornado better.
Step 12: Clean Up and Enjoy
Clean up any and all water spills.
Recycle the lids from the bottles.
Enjoy your taped tornado tube!
Step 13: Things We Learned
Things that we learned
1) The bottles that crush easier are no good for this.
2) Not all Duct tape is equal. Use duct tape that doesn't curl up when tearing into the smaller pieces.
3) Test outside. We were bound to get leaks with such small kids making theirs.
Step 14: Video
Here is a video of the step by step directions with the tornado in action.
Forward to 1:51 to see the small tornado tube in action.
Forward to 3:55 to see the larger tornado in action.
Tape Contest
Tape Contest
Be the First to Share
    • Sculpting Challenge
      Sculpting Challenge
    • 3D Printed Contest
      3D Printed Contest
    • Motor Vehicle Contest
    19 Discussions
    C8theGr8
    C8theGr8
    11 months ago
    I loved these things as a kid :)
    Cats Science Club
    Cats Science Club
    Reply 11 months ago
    Ever add food coloring or dish soap to the ones you made? Glitter? We added glitter before and talked about galaxies.
    C8theGr8
    C8theGr8
    Reply 11 months ago
    I certainly did! I liked to add silver-colored glitter. I did this as a home-schooler in elementary school in science.
    3D_Cre8or
    3D_Cre8or
    11 months ago
    Awesome yet simple project! I've designed a 3D printed adapter that connects two bottles to make tornadoes: https://www.thingiverse.com/thing:3270280. It's not 100% leak free, but if you print with 100% infill and over extrude a little, it should be very water tight.
    mmishko
    mmishko
    Tip 11 months ago
    Nice tornadoes. As the big chunk of this instructable is about taping and sealing the two bottles together, I just wanted to ask if you thought about gluing the lids top to top and drilling the hole through both to get the connector without buying one? Or just cutting the two tops and taping them as this is the tape contest;) Either way you'd end up with something that is more likely to seal, test it only the first time and keep it for the next time, unless the taping itself is an important part of this lesson.
    Cats Science Club
    Cats Science Club
    Reply 11 months ago
    Great questions. I have been making these for over 20 years and have tried all kinds of ways. I used to hot glue the lids together (after sanding them) and drill a whole between the lids. Worked but was a major weak point and the kids would break them in minutes of playing with them. Also tried supper glue, crazy glue, etc. and same thing.
    We just had a camp and made 28 tornado tubes. Most worked well and we had 1st and 2nd graders making their own (along with older kids too).
    Things that we learned 1) The bottles that crush easier are no good for this. 2) Not all Duct tape is equal. Use duct tape that doesn't curl up when tearing into the smaller pieces. 3) Test outside. We were bound to get leaks with such small kids making theirs.
    JohnC430
    JohnC430
    Question 11 months ago
    does the taller bottle work better than the smaller ones?
    Cats Science Club
    Cats Science Club
    Answer 11 months ago
    Hi. The larger bottles work better as in they have a longer tornado. Longer, skinny bottles also work well for the tornado to last longer. So I would say yes the taller the better.
    SilverL2
    SilverL2
    Question 11 months ago on Step 12
    Would hot-melt adhesive be less fiddly than multiple pieces of tape, and less likely to leak?
    Cats Science Club
    Cats Science Club
    Hi. Is hot-melt, hot glue? We tried hot glue and it doesn't work as well. Maybe a good start to keep things in place and then add all the tape. I like that idea.
    winneremerald12
    winneremerald12
    11 months ago
    Dude, this is so cool! Definitely going to show my younger siblings.
    Cats Science Club
    Cats Science Club
    Reply 11 months ago
    Thanks! Tomorrow/Monday we are making 30ish at our Spring Camp with 1st through 5th graders :-)
    Euan_R
    Euan_R
    11 months ago
    If you have never done this... you didn't have a childhood.
    brianchadorourke
    brianchadorourke
    11 months ago
    Thanks for pointing out how easy it is for tornadoes to form! A long time ago I was at state fair and they sold these connectors that allowed you to screw two bottles together (instead of duct tape). It was a lot of fun to swirl and get a vortex.
    Cats Science Club
    Cats Science Club
    Reply 11 months ago
    Thanks for looking at our instructable. They are fun and a bit addictive. Even our 76 year old grandma was having fun with it today. Seriously.
    Stan1y
    Stan1y
    I've read that several times I've seen there's reference to openings in the lids being alingeed, but not how you make them or I guess critically how big
    Cats Science Club
    Cats Science Club
    Hi. We just lined up the bottles without their lids (caps). No holes were made. Hope this explains the openings. Have fun building yours.
