Introduction: Trash Into Treasure: Twisted Coffee Table
Create a nice coffee table from wood leftovers.
Step 1: Find Wood Leftovers.
Check your local Woodworking Shop or yunkyard, and ask for any pieces of wood they don't need.
Step 2: Table Top
The pattern is made up from 20 stripes (3cm wide, 1cm thick) assembled and glued together to get a 28 x 28 cm square top. (CAD file available)
Step 3: Legs
Cut 4 legs type 1 (15cm long, 4cm wide, 4cm thick)
Glue each leg to the small 8.5x8.5 cm square piece.
To get the "twisted" motion, rotate each leg 90 º from the previous part.
Repeat the process with legs type 2 (the only difference is the incision on the top)
Step 4: Join the Legs Segments.
I stapled both leg segments together one on top of another and glued 4 stripes of wood to cover the center gap.
Step 5: You Got Your Twisted Coffe Table.
Adjust the table top and glue it to the top of the legs and you're done.
Makerspace Contest
Wood Contest 2016
Maker Olympics Contest 2016
