Introduction: Control Arduino With a Portable App
We are going to learn how to make an application to control arduino.
We will see how to:
- Easily make a windows application with python.
- Convert it as an executable to use it anywhere.
- Manage Serial ports (detection/reconnection) automatically with 1 line of code
We can even reuse the code to manage as many arduino as we want.
But before i tell you more about it, let's try utest first!
We will use it to control the internal led on an Arduino nano.
As always, all the documentation/code are available on github in english/french
http://github.com/pigetArduino/utest
Step 1: Upload Arduino Code
Frist we need to upload the code on the arduino.
- Download the source code: http://utest.madnerd.org
- Download drivers for arduino nano : http://nano.madnerd.org
On the Arduino software ( http://arduino.madnerd.org/ )
- Copy utest folder into your sketch folder
- Upload utest.ino
(Tools: Arduino Nano / Processor : Atmega328)
You will need an Arduino nano clone (ch340g) as the application will only detected it.
You can use the serial monitor, to test your arduino:
No Line Ending / 115200
UTest : return OK ON : Turn on internal led (pin13)
OFF: Turn off internal led (pin13)
Step 2: Control the Arduino With Utest
utest is a portable application, you don't need to install anything to make it works.
- Download the application : http://utestapp.madnerd.org
- Click on utest.exe
utest will automatically find the arduino
You can try to unplugged it/plug it on another usb port, and it will reconnect.
utest might not work on Windows 7 due to missing .dll
This shouldn't happen if your computer is up to date
Source: http://stackoverflow.com/questions/34218333/pyins...
Step 3: Create Your Own Application
Let's see how to reuse this application, to make your own application.
First we need to install python 3 to modify it.
- Download python 3 (https://www.python.org/downloads/)
- During the installation, tick Add Python 3.5 to PATH
Then we need to install pySerial, to communicate with our arduino.
- Open a command prompt (Windows key + cmd)
- Type:
pip install serial
Finally, test the application, it is available in the source code ( http://utest.madnerd.org ) at apps/utest/
- Go to the source code folder (apps/utest/)
- Type:
python utest.py
Step 4: Create the Interface
We have everything we need to modify our application.
Check out the source code : utest.py (github)
Let's see
- how to manage our arduino
- how to build a graphical interface with tkinter
In order to manage the arduino the easiest way possible, everything is handle by the module lib/usb.py
USB
As for now, this module has only two commands
usb = USB.Device(...)
- Connect to every serial ports which as CH340 in his name
- Send UTest to the serial port
- If it received "OK", it will connected to it
from lib import USB device_name = "CH340" #Device name in Windows device_type = "UTest" #Device type (in the arduino sketch) device_return_string = "OK" #Answer when a response is correct device_baudrate = 115200 #Baudrate usb = USB.Device(device_name,device_type,device_return_string,device_baudrate,status)
Everything is inside a separate thread to avoid blocking the application.
usb.write(string)
- Send a string to the arduino
- If the serial port is not available, it will try to reconnect
GUI (TKinter)
utest use tkinter to manage the GUI (graphical interface)
You can find more information on tkinter here : http://www.tkdocs.com/tutorial/index.html
- To create a window:
from tkinter import * root = Tk()
- To create a button ON
Button(text="on",command=on).pack()
- Create an action for the button ON
def on():
print("on")
- Create a label
status = Label(text="Searching...") status.pack()
If you want to modify a widget , we need to save it into a variable, and use .pack() on a different line
We send the label to the USB Moduleto display the current state of the connection
usb = USB.Device(...,status)
Finally, we generate the GUI loop.
root.mainloop()
Step 5: Add Commands to the Arduino
Our interface is ready,
but we need to teach our arduino to understand the commands we will send.
Check out the source code : utest.ino (Github)
Serial Functions
We use two functions to manage the serial communication.
serialManager()
Check the serial port and convert any messages to a string (inside readString)
serialCheck()
If UTest is received , answer OK
Device name
You can change the name of the usb device in the first line
const String usb_name = "UTest";
Add commands
We manage our commands inside void loop()
void loop() {
serialManager();
//If string received
if (readString.length() > 0) {
serialCheck();
if (readString == "ON"){
digitalWrite(13,1);
if (readString == "OFF"){
digitalWrite(13,0);
//We clean the serial buffer
readString = "";
}For each commands create a condition, for example to turn on the internal led when "ON" is sent
digitalWrite(13,1);
}Step 6: Convert Your App Into a Portable Executable
The arduino / Application is ready to be bundle into an .exe
- Install pyinstaller, we will use it to convert our application into an single executable file
pip install pyinstaller
- You can compile your application using the script compile.bat
pyinstaller --onefile --noconsole utest.py
- If you want to display debug messages, use this command instead:
pyinstaller --onefile utest.py
You should now have a /dist/utest.exe file
You will probably have warning about api-ms...dll file.
This shouldn't be a problem as these DLL (Universal C Runtime) are preinstalled on Windows 10 and previous windows should also have them if they are up to date.
Step 7: ... to Be Continued
I hope this was useful, and that will inspired you to create Arduino application !
With some modification, this application should works on MacOS / Linux.
Follow me on instructables/youtube, if you are interested by this topic.
Subscribe
Next time, we will learn how to improve our application and use it to control a led strip!
