Introduction: Upgrade DIY Mini DSO to a Real Oscilloscope With Awesome Features
Last time I shared how to make a Mini DSO with MCU.
To know how to built it step by step, please refer to my previous instructable:
https://www.instructables.com/id/Make-Your-Own-Osc...
Since many people are interested in this project, I spent some time upgrading it overall. After upgrading, the Mini DSO is more powerful.
Specification:
- MCU: STC8A8K64S4A12 @27MHz Get it from AliExpress
- Display: 0.96" OLED with 128x64 resolution Get it from AliExpress
- Controller: One EC11 Encoder Get it from AliExpress
- Input: Single Channel
- Sec/div: 500ms, 200ms, 100ms, 50ms, 20ms, 10ms, 5ms, 2ms, 1ms, 500us, 200us, 100us
100us only available in Auto Trigger Mode
- Voltage Range: 0-30V
- Sampling Rating: 250kHz @100us/div
New features:
- Show frequency of waveform
- Customize trigger level
- Auto, Normal and Single Trigger Mode
- Scroll waveform along horizontal or vertical
- Adjust OLED brightness in settings
Step 1: Watch the Video!
In this video, I will show you the changes, operations and functions about the new version Mini DSO.
Step 2: Prepare Your Part!
We need to add an indicator for new functions.
Material List:
- LED x 1 Get it from AliExpress
- Resistor 5k x 1 Get it from AliExpress
Step 3: Scheme and Circuit!
The changes in circuit is only to add a LED as indicator.
I will show you the use of the indicator later.
Protection of the circuit:
Last time I made a case with foam. The foam may produce static electricity. This issue need to be paid attention definitely.
This time, I use high temperature tape to do the protection.
Step 4: Download the Code!
Download the package below. There are source code and compiled hex file.
Also, available on GitHub: https://github.com/CreativeLau/Mini-DSO
If you do not want to read the codes, just burn the hex into the MCU.
Use a USB to TTL downloader and STC-ISP software to download the code to MCU.
Connect TXD, RXD and GND.
Download STC-ISP software here: http://www.stcmicro.com/rjxz.html
If the interface of STC-ISP is Chinese, you could click upper left icon to change the language to English.
For the detail configuration of STC-ISP please refer my previous video.
The codes were written in C. Use Keil software to edit and compile it.
Step 5: Introduction of Interface!
Parameters in Main Interface:
Seconds Per Division:
"500ms", "200ms", "100ms", "50ms", "20ms", "10ms","5ms", "2ms", "1ms", "500us", "200us", "100us"
Voltage Range:
Voltage is 0-30V.
Trigger Level:
Trigger voltage level.
Trigger Slope:
Trigger on Rising or Falling Edge.
Trigger Mode:
Auto Mode, Normal Mode, Single Mode.
Status in Main Interface:
'Run': Sampling Running.
'Stop': Sampling Stopped.
'Fail': The Trigger Level beyond the waveform in Auto Trigger Mode.
'Auto': Auto Voltage Range.
Parameters in Settings Interface:
PMode(Plot Mode): Show waveform in Vector or Dots.
LSB: Sampling Coefficient. Calibrate the sampling voltage by adjusting LSB.
100 times of voltage dividing coefficient. e.g. the resistor for voltage dividing is 10k and 2k, calculate the voltage dividing coefficient (10+2)/2=6. Get the LSB = 6 x 100 = 600.
BRT(Brightness): Adjust OLED Brightness.
Step 6: Introduction of Operations!
All operations are completed by the EC11 Encoder. The input include single click, double click, long press, rotate and rotate while pressing. It seems a little complicated, don't worry, there are details below. The resources of this encoder have been almost exhausted. If there are new features, may need additional input component.
Main Interface - Parameter Mode:
- Single Click Encoder: Run/Stop sampling
- Double Click Encoder: Enter Wave Scroll Mode
- Long Press Encoder: Enter Settings Interface
- Rotate Encoder: Adjust parameters
- Rotate Encoder While Pressing: Switch between options
- Switch Auto and Manual Range: Rotate Encoder clockwise continuous to enter auto range. Rotate Encoder anticlockwise to enter manual range.
Main Interface - Wave Scroll Mode:
- Double Click Encoder: Enter Parameter Mode
- Rotate Encoder: Scroll waveform horizontally (only available when sampling stopped)
- Rotate Encoder While Pressing: Scroll waveform vertically (only available when sampling stopped)
Settings Interface:
- Single Click Encoder: N/A
- Double Click Encoder: N/A
- Long Press Encoder: Return to Main Interface
Step 7: Introduction of Functions!
Trigger Level:
For repeating signal, trigger level could make it stable on display. For single-shot signal, trigger level could capture it.
Trigger Slope:
Trigger slope determines whether the trigger point is on the rising or the falling edge of a signal.
Trigger Mode:
- Auto Mode: Sweep continuous. Single click the encoder to stop or run sampling. If triggered, the waveform will be shown on the display and the trigger position will be put at the center of chart. Otherwise, the waveform will scroll irregular, and 'Fail' will be shown on the display.
- Normal Mode: When complete pre-sampling, you can input signal. If triggered, waveform shown on the display and waiting for new trigger. If no new trigger, the waveform will be kept.
- Single Mode: When complete pre-sampling, you can input signal. If triggered, waveform shown on display and stop sampling. User need to single click Encoder to start next sampling.
For Normal Mode and Single Mode, be sure the trigger level has been adjusted correctly, otherwise no waveform will be shown on the display.
Indicator:
Generally, the indicator on means the sampling is running. The more important use is in Single and Normal Trigger Mode, before get into the trigger stage, pre-sampling is required. The indicator will not on during pre-sampling stage. We should not input signal until the indicator comes on. The longer time scale selected, the longer waiting time of pre-sampling.
Save Settings:
When exit settings interface, all parameters in settings and main interface will be saved in EEPROM.
Step 8: Test It!
Test 1:
Capture the waveform during a switching power supply power on.
The waveform on Mini DSO is same as that on DS1052E. Small change in the waveform be captured clearly. The precision of voltage is decent.
Test 2:
Capture the waveform in a circuit measuring inductance and saturation current.
The Trigger Level is only 0.1V and sec/div is 200us. For such a small signal could be triggered, that’s pretty good.
Step 9: Limitation and Issues!
1. Same as the first version, it could not measure negative voltages. The waveform will stop at 0V.
2. If input PWM signal at high speed sampling, the sampling result would jump to maximum frequently. I asked STC engineer about this issue, but didn't get a clear explanation. This jumping issue also related to the quality of each MCU. One piece in my hand is very serious, and other pieces are better. But all of them have the sampling jumping issue.
Step 10: Further Plan!
Since there is sampling jumping issue in STC8A8K, and it is not so popular that hard to find. I decide to transfer this project to STM32. Meanwhile, I will try to find a simple way to measure negative voltage.
If you have advices or requirements about this project, please kindly tell me.
Hope you like it.
Feel free to check out my YouTube Channel: https://www.youtube.com/c/CreativeLau
