Introduction: Using Fusing (Glass)
This is a basic introduction to fusing glass. Fusing is a technique of joining pieces of glass together by melting them in a kiln.
Step 1: Tools
Kiln
Pyrometer
Glass prepared for firing
Fiber frax or kiln wash
Pyrometer
Step 2: Load Kiln
In this step, great care should be taken to ensure that the glass is properly spaced and clean.
Step 3: Fire the Kiln
The kiln is fired to 1575 degrees at which point the two glass pieces should be fused.
*This requires a separate instructable of firing schedules of temperatures depending on the type of glass, the thickness, desired result, as well as the kink of kiln you are working with.
Step 4: Finished Artwork
After the kiln is unloaded, view your work.
