Introduction: Capture the Image Using Ultrasonic Sensor With Arduino
I have been in IOT space for quite few months and trying to integrate things with Arduino board, Recently I came across Ultrasonic sensor, it is interesting. So I thought of creating a small project.The project goal is to capture the obstacle for security purpose using ultrasonic sensor with a camera.
Hardware used :
1) Ultrasonic sensor
2) Arduino UNO
3) Camera
Step 1: Hardware Explanation
Ultrasonic sensor
Ultrasonic sensor converts sound wave into electrical signal, they do both transmitting and receiving the signal, It will act like as an Transducer.Ultrasonic generates high frequency sound waves so the echo is received back to the sensor in between the transmit time and receiving time is calculated by the arduino and it will give the input to python. For reference you need more information about ultrasonic visit this link Ultrasonic.
Arduino UNO
Arduino is an open-source prototyping platform based on easy-to-use hardware and software.There are different types of arduino board available as per our requirements we select the boards in this project i am choosing the arduino UNO is a microcontroller board based on the ATmega328 (Datasheet). It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz ceramic resonator, a USB connection, a power jack, an ICSP header, and a reset button Arduino UNO.
Camera
In this project i am using web camera that capture the image based on the detection.
Step 2: Arduino Code
Arduino will receive the signal from Ultrasonic and given the signal input to python.
int trigger_pin = 13;
int echo_pin = 11;
float time_taken;
void setup() {
Serial.begin(9600);
pinMode(trigger_pin, OUTPUT);
pinMode(echo_pin, INPUT);
void loop() {
digitalWrite(trigger_pin, LOW);
delayMicroseconds(2000);
digitalWrite(trigger_pin, HIGH);
delayMicroseconds(10);
time_taken = pulseIn(echo_pin, HIGH);
Serial.println(time_taken);
delay(50);
Step 3: Python Code
Python program is used for getting the input signal from sensor via arduino, so that it can capture the obstacle according to the sensor detection.
#! /usr/bin/env python
import sys
import serial
import pygame
import pygame.camera
from os import getenv
from pygame.locals import *
from datetime import datetime as dt
# Initializing the Camera device
pygame.camera.init()
cam = pygame.camera.Camera("/dev/video0", (640, 480)) // Here declare the arduino port
home_dir = getenv('HOME')
Adjust the value of this variable to set the distance for the sensor to detect intruders
RANGE = 300
def capture_image(): ''' Starts the camera, Captures the image, saves it & stops '''
file_name = home_dir + '/image_captured/image_' + str(dt.now()) + '.jpg'
cam.start() image = cam.get_image()
pygame.image.save(image, file_name)
cam.stop()
Establishes a connection to Arduino board through serial interface
arduino_board = serial.Serial(sys.argv[1], 9600)
Enters an infite loop that runs until it receives Keyboard Interrupt
while True:
if arduino_board.inWaiting() > 0:
data = arduino_board.readline().strip()
try:
The value received through serial interface would be string, in order to process futher, it is converted to numeric datatype.
data = int(float(data))
if data <= RANGE:
capture_image()
print data
except BaseException, be:
initially the board might send some strings that are not the numeric value, to handle such exception it is catched and ignored by printing an exception message.
print be.message
Step 4: Run the Program
Declare the arduino port in Python program the above image shows the arduino UNO port connection.
For running the program save the python code, open terminal type => python “Your python project name”/arduino port name (example : python self.py /dev/ttys0 ). Arduino port name is shown in arduino ide choose Tools => Port => Port name is shown in ide.
Once all these settings are done, When you run the program Ultrasonic sensor will find the obstacles in an interval and capture the images using the camera.Hope this will give you some idea about using ultrasonic sensor with arduino using Python.
