Introduction: Viking Chair From 4, 2x4s
ABOUT
I've seen a few instructables on creating Viking Chairs from a single piece of wood, but wanted to look at building them from easier to manage 2x4s. Each chair is built from 4, 2"x4"x96" pine and cost around $10 each. When building these chairs if you want the chair to appear to be a single piece of wood, then you will need to cut off all rounded edges on any face that joins another face using a table saw.
Another options is to use pressure treated wood, then you do not have to finish the wood in the end if using outdoors.
Step 1: Cut Wood
Optional: Cut off corners (about 1/4") from all joining faces.
Take 2, 2"x4"x96" and cut according to the cut list. The angle cuts are more for decoration so those can be any size and any angle.
Step 2: Glue Together
Once all wood is cut, align the pieces and as shown in the layout. Run a bead of glue on all faces that are being joined together, and hold together with clamps until the glue is dried.
Layout and Dimensions
Back
- End Pieces- Width of 4 pieces (width varies depending if corners were cut) x 48"
- Center Pieces- 11" long. Leave gap equal to the thickness of the boards plus 1/16" so the seat can slide into the back. The remaining boards are about 35" long. The best thing to do is put 11" boards in place, then put some scrap wood where slot is, then add the longer boards and mark length then cut.
Seat
- End Pieces- 12" long.
- Center Pieces- 44" long, but can be cut shorter if you'd like the chair to have more of a recline.
Notes
- If chairs will be used outside, you should use glue made for outdoors, not basic wood glue.
- After chair was built I decided to attach some scrap wood (should have plenty left over from boards) around the opening on the back to prevent the boards from separating under strain.
- Some other options would to be to use long screws to attach the wood, or run wooden dowels threw the wood prior to gluing, or use biscuits/biscuit joiner to attach boards. Anything to help reduce the shear on the wood will help.
Step 3: Sand
Once the glue is dry, sand all of the faces of the boards. Using a power sander makes things go much quicker. I sanded with 100 then 220 grit. If you are trying for a very smooth finish you might want to go as high as 400.
Step 4: Check Assembly
Put your chair, or chairs, together and check to make sure the seat slides smoothly into the back. If it is tight, then sand any area that is causing interference.
Step 5: Paint, Stain, and or Clearcoat
Now you can paint, or stain your chair the color of your choice. I chose to use outdoor spray paint. After painted or stained, then apply a clear coat to avoid water from getting into the wood. You can use spray on or apply using a brush.
Step 6: Enjoy
Enjoy your chairs!
Second Prize in the
Flat Pack Contest
