Introduction: WAVE - the World's Simplest DIY Soldering Vise! (PCB Helping Hands)
About: I've been making Instructables since I was 13. Nowadays I'm busy studying Mechatronics, but I'm still active here, so feel free to reach out!
WAVE is probably the weirdest Helping Hands device you've ever seen. Why is it called "WAVE"? Because it is a Helping-Hands device that was built out of Microwave parts!
But the fact that WAVE looks weird, Doesn't mean that it can't be the best homemade "Helping-Hands for Soldering" device ever, Here I'll show you how I made it!
About a month ago, I built The Ultimate 14-in-1 Soldering Helping Hands Station. And as listed in the title, It has 14 different functions. The only problem is that the Helping-Hands aren't really that strong because they're made of a flexible material (They can hold ~500 grams, But when I solder, I put more pressure on the PCB, Which makes it fall...). This made me think of "Why does the arm need to be flexible?" "It just makes it uncomfortable"!
I decided to make one that doesn't have flexible arms, Is strong enough to hold any PCB, And will never fall over, Which is: WAVE!
Ok, Enough! Let's get to work!
Step 1: What You'll Need
Materials:
A Small Aluminum Vise How can it cost only $3?!)
Self Adhesive Rubber Feet
A Big Microwave Transformer (Mine weighs ~3.5 Kg.)
Metal Epoxy (Or a Welder, If you have one...) +Mixing Stick
Silicone Adhesive
Tools:
Metal File / Sanding Stone
Vise (A real one, Now as a tool)
Hacksaw
Why: Because Circuit Boards don't hold themselves!
Protection Gear Needed: A Respirator
Cost (for me): <$3.50
Needed Skills: Sawing, Epoxy-ing
Approximate Time: 30 Minutes
Step 2: Saw the Vise (Saw Off the Screw Part)
I used a hacksaw to saw off the part of the vise that holds it on the table, It was really easy because the vise is made of Aluminum.
I kept the screw part of the vise in case I would need it for another project, Such as turning it into a C-Clamp :)
WARNING: I bought a cheap Vise so I could make this project, Do not ruin a real vise! A Hacksaw won't be strong enough to cut through a real vise anyway...
Step 3: Roughen the Surface of the Vise & Transformer
To help the Epoxy adhere better, I roughened the surface of the Vise and the Transformer with a metal File.
Step 4: Glue the Vise to the Transformer W/ Epoxy
After making sure that the surface was rough enough for the Epoxy to adhere well, I smeared some Epoxy onto the vise and stuck it onto the Transformer. I also added some more epoxy around the edges to strengthen the adhesion even more, As shown in Picture #2.
Step 5: Add the Rubber Feet
I added some self adhesive rubber feet to the bottom of the Transformer so it wouldn't scratch my worktable. If you don't have these rubber feet, You can add a dab of hot glue in each corner
Step 6: Upgrade the Strength of the Jaws Grip (On the PCB) W/ Silicone Adhesive
I wanted to ensure that the grip on the PCB was at its best, So I added smeared a thin layer of SIlicone Adhesive onto the the Jaws of the Vise. This helps add more friction which makes the PCB sit firmly in the Jaws.
Bonus: The silicone also protects the PCB from getting scratched by the Jaws (If that's even possible), And because Silicone is an insulator, It stops any accidental Short-Circuits (If the paint gets removed from the vise after a long time)
DONE!
Don't forget to Follow me on Instructables, I have over 60 Instructables that I'm sure you'd like!
