Introduction: Wall Table (mesa De Pared)
It happens that I'm in the garage doing some little tweak, or simply ordering my stuff, and I need a table or something to support things. I can improvise a table with the aluminum ladder, but that means moving it and putting it together, then turn back around. Because of this need, and I got free a few pieces of plywood in good condition, I decided build a wall table, foldable so it does not take place when not in use. Ideas dominant in all my projects, in order of importance, are: feasibility, safety, economy and ease.
(Suele sucederme que estoy en el garage haciendo algún pequeño arreglo, o simplemente ordenando mis cosas, y me falta una mesa o algo parecido para apoyar cosas. Puedo improvisar una mesa con la escalera de aluminio, pero eso implica desplazarla y armarla, y luego volver atrás todo. Debido a esa necesidad, y a que conseguí gratis unos trozos de aglomerado enchapado en buen estado, decidí construir una mesa de pared, abatible para que no ocupe lugar cuando no está en uso. Las ideas dominantes en todos mis proyectos, en orden de importancia, son: factibilidad, seguridad, economía y facilidad).
Step 1: Starting (Empezando)
The first step was deciding where to place it. Then I had to search through my saved things (I do not throw anything away) some pieces of strong rope. I decided I could use this rope to replace the hinges, advantageously.
I took a piece of melamine veneered plywood, of a size suitable to my need, and I made four holes of 6mm in diameter, near each of the corners. Then cutted two short pieces of rope, about 15 cm each, and tied them tightly in the form of loop. Then I did the same with two pieces about 80 cm each. Walks holes in wood using a piece of wire. I had to enlarge each hole in an end for the knot, so that it enters a little below the surface of the plywood and not be an obstacle.
I made two 8mm holes in the wall, to accommodate two separate fischer plugs, and screw on the wall the small loops as hinges, with screw and washer. I tried to keep horizontal, for which I used a level of those cheap Chinese. I set the altitude to work standing up, at the height of my navel.
I made a notch or recess in the wood that was against the screws with washers, so that not clash with them.
Lo primero fue decidir el lugar donde ubicarla. A continuación tuve que buscar entre mis cosas guardadas (yo no tiro nada a la basura) algunos trozos de soga resistente. Decidí que podía usar esta soga en reemplazo de las bisagras, ventajosamente.
Tomé un trozo de aglomerado enchapado en melamina, de un tamaño adecuado a mi necesidad, y le hice cuatro agujeros de 6mm de diámetro, cerca de cada una de las esquinas. A continuación corté dos trozos cortos de soga, de aproximadamente 15 cm cada uno, y los anudé fuertemente en forma de lazo. A continuación hice lo mismo con dos trozos de aproximadamente 80 cm cada uno. Los pasé por los agujeros de la madera usando un pedazo de alambre. Tuve que agrandar en cada agujero la parte correspondiente al nudo, para que este entrara un poco bajo la superficie de la placa y no resulte un obstáculo.
Hice dos agujeros de 8mm en la pared, para alojar sendos tacos fischer y atornillar contra la pared los lazos pequeños, a modo de bisagra, con tornillo y arandela. Traté de mantener la horizontalidad, para lo cual usé un nivel de esos baratos chinos. La altura la fijé como para trabajar de pie, a la altura de mi ombligo.
Hice una muesca o rebaje en la parte de la madera que daba contra los tornillo con arandela, para que no choque con ellos.
Step 2: Ending (terminando)
Finally I put on the wall the hook bracket screws, also with fischer plugs and a few inches above the table. I had to use the level again, to ensure the horizontal.
Finalmente puse en la pared los tornillos ganchos para colgar los soportes, también con tacos fischer y unos centímetros más arriba que la mesa. Tuve que usar nuevamente el nivel para asegurar la horizontalidad.
