Introduction: Water Gun Flame Thrower
About: i like to play with fire and build stuff like tech and all that
This is an instructable that shows you how to build a flame thrower out of a water gun and house hold materials!
WARNING: I AM NOT LIABLE IF YOU GET BURNED, HURT AND/OR ANY OTHER INJURY
DO NOT USE THIS IN ANY ILLEGAL WAY
Step 1: Step 1
first off the materials you need for this is:
- Water gun (super soakers are better for this but i dont have one)
- alcohol (i use 91% but they both work)
- JB Weld
- something to spread the JB Weld (i used the back part of a nail file)
- aluminum foil
- duct tape (any color) or and other strong tape works
- flexible lighter
- rubber stopper or something an in diameter
- knife (might come in handy)
Step 2: Step 2
First, mix a little JB Weld together and cover the nozzle of the water gun (try not to cover the hole where the water shoots out from) . It helps if you put a needle in there about half way in.
Step 3: Step 3
After it drys cover it with about three layers of aluminum foil (make sure u poke out the hole). This helps the plastic from being burned or melted.
Step 4: Step 4
tape the aluminum foil with duct tape so that it doesn't fall off.
Step 5: Step 5
take the top part of the flexible lighter (just the flexible top part). then put some kind of wire through it. Make sure the wire sticks out about an inch or about 3cm. Now bend the top part of the flexible tube, it should stay in shape now since it has a wire inside.
Step 6:
now put the whole flexi tube through the rubber stopper and tape it onto the water gun so that it is about 1-1/2 inch away from the nozzle.
Step 7: Now You're Finished!
just fill it with alcohol and put a small piece of paper on the wire on the front and light it up and spray it and there you go a flame thrower!
