Introduction: Watermelon Brain
This watermelon will make a great substitute for a cake at your next halloween party. With only a watermelon, a paring knife, and a little patience you can make this awesome, eerie looking fruit that will have your party guests in awe. So follow this instructable to learn how to make it.
Step 1: Selecting a Melon
For the materials all you need is a regular paring knife, a vegetable peeler, a cutting board and a watermelon that is slightly longer than it is wide, you know brain shaped. this is the water melon I used.
Step 2: Peeling the Melon
To peel the melon peel it as you would peel any other fruit. just larger. You must peel of all of the green skin, and a little bit of the white rind until just a tiny bit of read can be seen through the white. This will give your brain a nice pinkish brain color. Peeling takes a long time but it does not need to be perfect. The general idea is just git rid of the green skin.
Step 3:
When you are finished peeling it should look like this.
Step 4: The Brain Pattern
There are many different ways to carve the brain into the water melon. The way that I did it was to first carve a line down the middle to divide it into two hemispheres. The best way to carve is to cut using wedges. This is the best way to let the red show while still making a nice clean line.
Step 5: Carving
After you have created the line, you can carve any pattern of brain you would like. A quick google image search is generally a good way to find a carveable brain to replicate. In general though, squiggly lines look relatively brain-like. To carve well it requires a lot of patience because you cant erase what you have carved so it is best to take it slow. After a while your carving should start to come along.
Step 6:
After a while you are done and you can plate your brain however you would like.
Enjoy carving your own watermelon brains. please comment if you have any suggestions or ideas for future projects. thanks
