Introduction: Web Enabled Garage Door (Raspberry Pi)
Goal to create a web based garage door opener that should retrofit to most standard openers. Tested with circa 1990s Chamberlain 1/2 hp opener. Once competed your garage door could be opened from your cellphone or computer.
Raspberry PI - Raspbian (Rev B used for these instructions but should adapt to other versions)
1 BreadBoard
Jumper Wires
1 5v Relay (GS-SH-205T depicted)
1 Transistor (2N-2222-A338)
1 Diode
1K resistor
Bell Wire (or similar)
and of-course a garage door opener
Assumptions:
Raspberry Pi has a power source
Raspberry Pi is on your home network either via Wireless Adapter or Wired
Step 1: The Circuit
To cause the Garage Door to open we will use a Relay to mimic the pressing of a garage door opener button.
We are going use one of the 5v pins to charge the relay. To do this on demand we use a transistor to switch the 5v circuit on and off using one of the GPIOs.
The diode is used to allow the relay coil to discharge slowly preventing undue stress on the Pi circuitry.
Here is a reference to the Pi Pin layout as it relates to these instructions and to WiringPi the software used to control the GPIO which we will discuss later.
The 2 leads wire to the Garage door opener in the same way a wired switch is wired to the opener.
Note: Be sure to check your transistors pins so you don't blow up your Pi. In this example the 5v circuit is attached to the Transistors Collector, the GPIO pin is attached to the Transistors Base and the Pi's Ground is connected to the Transistors Emitter.
Step 2: PI Software
Starting with a Pi that is running Raspbian we Install the following software. (To keep this instructable simple I have linked to instructions for installing these.)
Apache (WebServer) Part 5
FTP (Convenient way to update the WebContent) Part 7
WiringPi (Command line GPIO controls)
Step 3: The Button (Garage.html)
The first file on our Website is Garage.html which contains minimalistic code to provide a button for us to interact with. You can of-course elaborate on this to your hearts content, but this is bare bones.
<html><body>
<form action="Garage.php" method="get">
<input type="submit" value="Open Garage" style="width:500px; height:100px;font-size:80px;border-radius: 25px;
background-color: 2DA3A7;" >
</form>
</body></html>
<html><body>
</form>
</body></html>
Step 4: The Working Code (Garage.php)
To cause an action to run on the Apache server we turn to PHP. Garage.php simply needs to exist in the same directory of the Pi as Garage.html does.
This code:
1)Puts the GPIO pin into Out Mode
2)Turns the pin on
3)Waits 2 Seconds to ensure the Opener gets the signal
4)Turns the pin off
5)Puts the pin back in IN mode as a measure of safety (Out pins are easy to fry In pins are more difficult)
6)Returns us to the button (Garage.html)
<?php
$on = 'gpio mode 0 out';
$off = 'gipo mode 0 in';
$command = 'gpio write 0 1';
$command2 = 'gpio write 0 0';
exec($on);
exec($command);
sleep(2);
exec($command2);
exec($off);
header ("Location: Garage.html");
This code:
2)Turns the pin on
4)Turns the pin off
<?php
exec($on);
exec($command);
sleep(2);
exec($command2);
exec($off);
Step 5: Using Your New WebPage
Now that we have all the software in place and our new WebPage is available let's take a look at it.
While on the same network as your raspberry Pi you can access the WebPage by typing in your Pi's IP address.
Should look something like this where 192.168.1.30 would be replaced with your Pi's IP address
http://192.168.1.30/Garage.html
Press the Button and your Garage door will open or close.
Step 6: Making Your Button Available From Anywhere in the World!
Note: Making your new WebPage available over the internet could pose a security risk if measures are not taken to prevent any Joe Shmoe from opening your garage door. At a minimum your Garage.html should require a 4 digit code and limit the number of failure requests. However security is beyond the scope of this Instructable. You have been warned. Use at your own risk.
To make your webPage available over the internet you will have to pass HTTP traffic to your Pi's IP address. You should look up the instructions for your own router but for mine it is quite simple. Log into the router's admin page in the advanced settings select port forwarding. Select HTTP as the service and enter the IP Address of your Pi. Now your webPage is available from anywhere in the world.
To get to it from outside your home network you will need the IP address your ISP assigned to you. This IP address is easy to find just go to http://whatismyipaddress.com/ and the page will show your IP address below the text "Your IP Address Is:" Now simply plug that in as the address we used earlier and voila you can now open your Garage door from anywhere in the world.
Example:
http://16.32.64.128/Garage.html
Example:
