Weber Grill Pizza Oven Conversion - Homemade KettlePizza
8,833
89
10
I've always wanted to build an outdoor pizza oven. The problem is, it takes up quite a bit of space and the cost is pretty high. I recently stumbled on the KettlePizza Pro. It essentially turns any kettle style grill into a pizza oven. Although cheaper than a pizza oven, the price tag was still relatively expensive. I figured I'd try to build one of my own. In the end I was able to create a pizza oven attachment for roughly $50 and it easily got up to temperatures nearing 700F.
Teacher Notes
Step 1: Initial Steps
I started off by contacting a local metal fabrication company and asked for a 6 foot by 7 inch piece of 18 gauge steel. I had originally planned to use stainless steel but it was going to cost $78. I opted for regular steel for $45. They also were able to put it through a roller to assist the ring formation. I fit the ring onto my 22 inch Weber Grill and marked it with a sharpie. I put on the lid and marked the top and bottom lines. With the measurements in place, I went back inside to start drilling and cutting.
Step 2: The Metal Ring and Pizza Slot
I first drilled two holes and connected the ring with a couple of nuts and bolts. Then I put my pizza peel on top of the ring and marked 4 inches on either side fore the slot width. Next I drew two lines for the top and bottom cuts. I made the top 1 inch shorter on either side. This slot size was designed for a 15 inch pizza peel I picked up at a local restaurant supply company for $7 and a 15 inch pizza stone purchased from Amazon. With the pizza oven opening drawn, I cut out the slot with my angle grinder fitted with a cutting wheel. I used a metal file to grind off the sharp burrs.
Step 3: Handles
I then cut two 5.75 inch long pieces of 2"x2" scrap wood for the handles and fit those to the ring. These were spaced a few inches away from the oven's opening. I used four, 6 inch long carriage bolts and 12 nuts to fix them to the ring. The last thing to mount was the thermometer. With everything assembled and mounted where it needed to be, I took the the handles and thermometer off, took the oven outside, and gave it a few coats of high temperature paint only on the outside surfaces.
Step 4: The Dough and the Pizza
For the dough, I used a slightly modified recipe from SeriousEats.com. 20 oz of High Gluten Bread Flour, 0.3 oz Kosher Salt, 0.2 oz Sugar, 0.2 oz of yeast, and 12 oz of water. I mixed all the ingredients, covered the bowl with cling wrap, and left it out on the counter for a few hours to jumpstart the yeast. I then split it into 4 dough balls and placed it in the fridge for 2 days to develop the flavor. On the day of the cook, I pulled the dough out and left it on the counter to warm up a bit. I sliced the fresh mozzarella and placed it on a paper towel to wick away some of the moisture. For the sauce I just used a good brand of peeled whole tomatoes. I drained out the juice and used an immersion blender to buzz them up into a sauce. I started some charcoal and placed some chunks of wood around the edges of the grill and waited for the stone/grill to get up to temperature. The pizzas came out fantastic and I believe they were some of the best I've ever made at home. The dough was moist and chewy on the inside and the outside was super crunchy and crisp. The bottom and edges had those slightly charred bits that give the curst a delicious flavor!
Barbecue Challenge
First Prize in the
Barbecue Challenge
    • Spicy Challenge
      Spicy Challenge
    • Stone Concrete and Cement Contest
    • Classroom Organization Challenge
    10 Discussions
    Cueball21
    27 days ago
    Great job!!!
    You can buy ones like you built for over a hundred bucks on Amazon; so you 'done good!'
    I agree that stainless steel is overkill. After all, its only role is to contain heat; no food will touch it.
    Have you tried to raise the height of the pizza stone to make it more or less level with the rim of the kettle bottom's edge? Raising it to that level should make placing and taking 'pies' a lot easier. I'm thinking about 3 fire bricks should do the job of raising the coals rack where the pizza stone sits to that level. It might take some adjustment with an angle grinder.
    Again, GREAT JOB!!!!
    Dandeman321Cueball21
    Reply 27 days ago
    Thank you! Yes, that was my motivation for the project. The full Kettle Pizza kit with a stone and pizza peel was nearly $200 on Amazon! I have not tried raising the stone. I didn't have much trouble at all getting the pizzas in and out since they were smaller. Just gotta make sure you have enough flour/corn meal on the bottom so they slide nicely. The photo/angle is a bit deceptive, it's probably about an inch and a half below the lip of the grill insert.
    charlessenf-gm
    4 weeks ago
    " took the oven outside, and gave it a few coats of high temperature paint "
    What color? It does not look 'painted' in the pics!
    Neat trick BTW!
    Save the bit you cut for the access/opening maybe figure a way to use it as a 'door' for your oven to retain even more heat.
    Dandeman321charlessenf-gm
    Reply 4 weeks ago
    Silver high temp paint! That is a great idea! I think i threw that piece out unfortunatly. I'll have to look in my scrap pile and see if I can find it.
    mcopadoivak245
    Reply 4 weeks ago
    He says it in the part talking about the dough- it's on a pizza stone.
    Dandeman321mcopado
    Reply 4 weeks ago
    Yup! Just a 15 inch pizza stone from Amazon. Clarified it in step two.
    actranslation
    4 weeks ago
    Yes, I am going to try this.
