WiFi WebSocket Remote Robot
4,437
15
Introduction: WiFi WebSocket Remote Robot
About: Make it yourself if you cannot buy one!
This instructables show how to use ESP8266 module as a HTTP + Web Socket server to build a low lag time (fast response) WiFi remote robot.
Teacher Notes
Step 1: Why WebSocket?
There are tons of WiFi remote robot on the web. Most of them have a simple web interface that can control the robot by a few arrow buttons. It is good enough for demonstrating the circuit works. However the response time is too slow even compare it with a few bucks RC car :(
Every remote control command can be only 1 or 2 bytes, but a single HTTP request introduce hundreds bytes overhead and require wait establish a new connection each time. WebSocket can eliminate this overhead and get over 10 times of performance gain.
You may not familiar with Web Socket, but the implementation can be very simple. This Arduino source code file only 5 KB in size, already included client side HTML + Javascript and server side HTTP + Web Socket server. It is a good starting point for learning Web Socket.
Ref.:
https://blog.feathersjs.com/http-vs-websockets-a-p...
https://medium.com/platform-engineer/web-api-desig...
http://blog.arungupta.me/rest-vs-websocket-compari...
https://www.slideshare.net/alinone/from-push-techn...
https://en.wikipedia.org/wiki/WebSocket
Step 2: Preparation
ESP8266 Dev Board
Any ESP8266 Dev Board should be ok, this time I am using NodeMCU.
Motor Driver Board
Any 2 motors driver board should be ok, this time I am using L9110S.
2WD Robot Chassis
Any 2WD Robot Chassis should be ok, I have no one in hand, so I simply use some LEGO to make one.
Battery
ESP8266 operate at 3.3V, most Dev Board have a regulator to make it. In most case it can powered from the range of 5V - 12V. I am using a 8.4 V rechargeable battery with battery holder this time.
Step 3: Software
Arduino IDE
Download and install Arduino IDE if not yet:
https://www.arduino.cc/en/Main/Software
ESP8266 Support
Follow the ESP8266 official steps to add ESP8266 support if not yet:
https://github.com/esp8266/Arduino
Step 4: HTML & Javascript
The Web Socket remote can break into 2 parts, client side and server side. Client side is a simple webpage for the mobile phone. The main area is a canvas, once you touch and swipe on it, the x and y coordinates values will pass to server side via the established Web Socket connection. Below is the complete web page source code, it has minified to a single line string value in Arduino source code:
<p><!DOCTYPE html><html><head><br><meta name='viewport' content='user-scalable=no,initial-scale=1.0,maximum-scale=1.0' />
<style>
body{padding:0 24px 0 24px;background-color:#ccc;}
#main{margin:0 auto 0 auto;}
</style>
<script>
function nw(){return new WebSocket('ws://'+location.hostname+':81/',['arduino']);}
var ws=nw();
window.onload=function(){
document.ontouchmove=function(e){e.preventDefault();};
var cv=document.getElementById('main');
var ctop=cv.offsetTop;
var c=cv.getContext('2d');
function clr(){
c.fillStyle='#fff';
c.rect(0,0,255,255);
c.fill();
function t(e){
e.preventDefault();
var x,y,u=e.touches[0];
if(u){
x=u.clientX;
y=u.clientY-ctop;
c.beginPath();
c.fillStyle='rgba(96,96,208,0.5)';
c.arc(x,y,5,0,Math.PI*2,true);
c.fill();
c.closePath();
}else{
x=128;
y=128;
x=x.toString(16);
y=y.toString(16);
if(x.length<2){x='0'+x;}
if(y.length<2){y='0'+y;}
if(ws.readyState===ws.CLOSED){ws=nw();}
ws.send('#'+x+y);
cv.ontouchstart=function(e){
t(e);
clr();
cv.ontouchmove=t;
cv.ontouchend=t;
clr();
</script>
</head>
<body>
<h2>ESP TOUCH REMOTE</h2>
<canvas id='main' width='255' height='255'></canvas>
</body>
</html></p>
Step 5: Pins Connection
Here is connection summary:
ESP8266 Dev Board -> Motor Driver Board
Vin               -> Vcc                -> Battery +ve
GND               -> GND                -> Battery -ve
GPIO4  (D2)        -> A-IA
GPIO0  (D3)        -> A-IB
                      Motor A           -> Left motor
GPIO14 (D5)        -> B-IA
GPIO12 (D6)        -> B-IB
                      Motor B           -> Right motor
Step 6: Upload Program
  1. Download ESP Web Socket Remote source code at Github: https://github.com/moononournation/ESPWebSocketRem...
  2. Open ESPWebSocketRemote.ino in Arduino IDE
  3. Connect your ESP8266 Dev Board
  4. Select your ESP8266 Dev Board type and Port at Tools Menu
  5. Press Upload
Step 7: First Time Setup Steps
Most WiFi robot ask you connect to it from your mobile, but I don't think it is the right method. Because it means anyone's mobile can connect to your own robot. And also every time you need to wait your robot WiFi AP start and then use your mobile search the WiFi and connect it, it is a little bit time consuming.
I think the right method should be the robot auto connect to your mobile hotspot while boot up.
But I still don't want to store my hotspot credential in source code, WiFiManager can help me solve this.
WiFiManager will auto try to connect last connected WiFi. If failed, start a AP and captive portal wait you input the WiFi details and then reboot.
So the first time setup steps are:
  1. Turn on ESP8266 Robot
  2. Connect to "espweremote" AP
  3. Fill in your mobile phone hotspot details
Step 8: Connection Steps
  1. Turn on mobile phone hotspot
  2. Turn on ESP8266 Robot
  3. Wait ESP8266 Robot connect to mobile phone hotspot
  4. Open mobile web browser and browse to http://espwsremote.local/
  5. Touch and swipe on the canvas (the white square) to control the robot
Step 9: Happy Remote!
It's time to play your low lap time remote robot!
Step 10: What's Next?
ESPWebSocketRemote is a very simple example, you can do much more on it.
E.g.:
  • use PWM change both motors speed while swiping on different coordinates
  • add more control such as robot light, arm and even launch rockets :>
  • decorate the HTML layout
  • build a bigger robot
Electronics Tips & Tricks Challenge
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    3 Discussions
    tcaschy
    tcaschy
    6 months ago
    Hi, thank you so much for this tutorial! I have my wifi robot working on my mobile but I'm curious, how can I use an HTTP GET command from say a computer to control the robot via the web socket code? Or even using curl?
    Fabio_R_57
    Fabio_R_57
    7 months ago
    Hello , very good job !!
    I wish I could do things like that , but it's far too 'dark' to me...
    I am struggling to make a simple NodeMcu talk with an AppInventor2 app I would make but converting the usual 'ON/OFF' led or relay,via slow HTTP ( which is already working for me ) , to the much faster Websocket solution ...but I do NOT know to create the client side on my smartphone...
    Could you give a hint, if you have one?
    Thank you so much , regards
    Fabio R. -- Rome
    陳亮
    陳亮
    Reply 7 months ago
    Hi Fabio, in this instructables, all code and HTML stored at ESP8266. Thats mean you do not require an extract client e.g. AppInventor2. Simple use your mobile share WiFi to the Robot and then browse to the Robot webpage to control it. The only things you need to revise is the HTML and some simple GPIO response on the WebSocket message.
