Introduction: Window Planter Made From Old Pallet. Window Sill Herb Garden
This is my first instructable,
I designed these (well not really designed), more cobbled together, when i was looking for uses for the off cuts of pallets that i didn't reuse for the climbing frame ive made.
So yeah it took like 30 mins per one. cost about 50p.
Step 1: Tools and Ting.
Tools:
I used a mitre saw because im lazy and crap at sawing wood straight.
16mm spade bit to make a drainage hole.
screwdriver.
Table saw
belt sander (again, because im lazy)
Materials
End of a pallet
piece of wood which can serve as a base
some screws.
Step 2: Construction.
Its fairly self explanatory. I sanded down all the surfaces with a 40 grit sanding belt.
cut two pieces of wood the size of the holes. They aren't perfectly straight but it doesnt really matter.
Drilled two holes in each one after i screwed them in place.
Step 3: Wang a Bit of Varnish on It.
just something to postpone the rotting process, which is inevitable but at least it looks ok and fits onto a window.
fill with soil and seeds.
BANG
its a window sill herb garden made from a bit of an old pallet!!
Instructables Green Design Contest
Great Outdoors Contest
