Wireless Bell System
2,528
12
Introduction: Wireless Bell System
The problem that fix this project is the following: at the high school where I work, the class-change bell doesn´t sound loud enough everywhere and sometimes it causes some problems. Install a new wired class-change bells or buy a wireless bell system isn´t possible by the moment.
This project could be useful too, for everybody that need to replicate a main bell in a wide area without install a wired or wireless system bell, not expending much money and, of course, made by you.
Thinking in a solution and looking for similar projects, I found the followings projects here in instructables: Wireless Doorbell transmitter and Wireless Doorbel receiver. There was what I need but instead of using PIC microcontrollers I have decided to use Arduino microcontrollers and its components.
So, I proposed to the high school principal a simple and easy solution: to build a wireless class-change bell system. The solution is to install closed to the class-change bell a device with a sound detector controlled by a microcontroller that sends a signal to others receivers stations with bells when the class-change bell sounds. It´s easy and cheap.
See below the solution implemented it and how it works.
Teacher Notes
Step 1: List of Material
The solution implemented is based in a master/slave model where the master station or transmitter station is installed near the main class-changed bell and the slaves or receiver stations are installed in differents places. In this project we have configured the sound sensor station and only one bell repeater but it is possible to configure more ones. Initially the system is configured for five receivers stations but you can modify it.
So the material for the transmitter station is the following:
and the material for each receiver station:
Step 2: How to Connect and Program a Receiver Station
A receiver station is continously listening the wireless network waiting for the activation signal sent by the transmitter station manually or automatically when the main bell rings. While the signal is been receiving, it activates the relay to connect the secondary bell.
Step 3: How to Connect and Program a Transmitter Station
The transmitter station is continously measuring the sound level using the sound sensor installed close to the main bell to detect when it rings. While the main bell is ringing it is sending the activation signal to all the receivers station. Moreover I have installed a button to send the activation signal manually in case the main bell is out of service. While the button is pushed the station is sending it.
Step 4: Configuring the Transmitter Station
As you can see in the picture 2, the measurements before and after the main bell rings are stable (150, 149, 151, 149, ....), but when the main bell rings the analog measurements change between 95 and 281. The sketch I have programmed (see picture 2 and 3) will automatically detect the stable measuremet and will send a signal to the receivers stations when the diference, in absolute value, between the stable value and the current measurement is upper to a fixed threshold and remains during a number of readings.
For this project this value is fixed to 4 (4% up or lower the stable value) as you can see in the code below.
To configure this value, you have to do the following:
  • You have to build the transmitter station with the sound sensor and install it near the mail bell (picture 1 or picture 4)
  • Download and load the sketch "transmitter.ino" (see previous step)
  • Test if the led remains on while the bell is ringing.
    • If the led is off, you have to change the threshold ("min_threshold_to_send_signal" in the code below) to adjust the sound sensor to your bell and repeat the test. .
    • If after several trials the led is on when the bell rings and off when it doesn't rings, you have finished the configuration.
You can modify, if you need it, the delay time between two measurements ("delay_between_reads") or the maximun level sound threshold to consider the same level sound ("max_threshold_to_consider_same_value").
#define delay_between_reads 200
float min_threshold_to_send_signal = 4.0;
float max_threshold_to_consider_same_value = 1.0;
Step 5: Final Installation
Step 6: From the Beginning ...
Remix Contest
Remix Contest
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    2 Discussions
    audreyobscura
    audreyobscura
    1 year ago
    It's great that you were able to work with your school to make a project that would solve a school-wide problem! Awesome job!
    TecnoProfesor
    TecnoProfesor
    Reply 1 year ago
    Thank you very much for your kindly comment
