Wood-fired Pizza on a Gas Grill
4,538
36
14
Pizza is dead easy to make and are sure fire hit with any crowd!
This method will have you cooking pizza on your basic Gas Grill that is as good as any traditional wood fired oven.
Step 1: First Make the Pizza
Use a packet of “Crusty” bread dough mix for bread machines, these packets have everything you need.
Most bread machines have a dough cycle or use a mixer with a dough hook - just follow the instructions on the bread mix packet for "Hand Kneaded" or Bread Rolls, this dough has a little less water and will produce a stiffer dough.
A 3’ish cup mix will give 4 medium pizzas (thin crust) or 2-3 thick spongy ones
Once the dough has formed, coat the inside of a large container with oil, place the dough in it and set it aside to prove.
Step 2: Roll Out the Dough and Prepare the Base
Once the dough has proved, divide it into portions.
Roll a portion out into a circle, the same size as your pizza tray
Flour the pizza tray and transfer the dough to it
Step 3: Dress the Pizza
I've never got time to make my own sauce because I'm an impulsive bastard so when I want pizza, I want it now!
Choose a good Passata, and add some crushed garlic to it. If you can remember, do this at the same time as you mix the dough, the little bit of time the garlic has to infuse the passata will greatly improve the flavour.
Spread the Passata evenly over the pizza base.
Step 4: Add the Toppings
Now the fun part!
The choice of toppings is up to you, just remember a couple of rules:
  • Cut everything as thin as you can, this will help the toppings cook quickly
  • Avoid Moisture, Wet toppings or toppings that release moisture as they cook will make your pizza soggy, squeeze the moisture out of things like olives, pineapple etc
  • Don't put too much on! The thicker the layers of toppings the longer it will take to cook and the soggier your pizza will be.
Start with a layer of cheese, this helps stick the ingredients to the base, I like to finish with a little cheese as well, this will stop bits from falling off.
Step 5: Set Up Your Gas Grill
If you have a four burner gas BBQ with a hood, remove the solid plate and move the grill bar plate to the centre of the barbecue, get the barbecue nice and hot by using all burners on high then turn the centre ones back to low before cooking.
Eliminating the solid plate helps the air flow around your pizza and will give a nice crisp crust.
Place three empty cans on the grill, the pizza tray will sit on top of them, this places the pizza up into the hottest part of the BBQ Grill where all the hot air is circulating and it creates some distance between the base and the direct heat from the flames. Setting it up like this will ensure your toppings will be cooked when the base is.
Devise a method to ensure nobody throws your cans out, I have found that small children and visiting mother-in-laws universally understand simple symbols which spouses apparently do not
Step 6: The Wood-fired Cheat
To get that "wood-fired" taste on your pizza, you don't need a lot of smoke, just a thin wisp.
One of those stainless steel trays full of wood-chips will do the trick set down on the burners, but more often than not, I just sit a small wooden block directly on the back of an exposed burner
Step 7: Cook That Pizza!
Light the burners and get the Gas Grill as hot as you can.
Place the Pizza tray on top of the cans, close the lid and set a timer for 5 minutes.
After 5 minutes check your pizza, look at the toppings and lift a corner of the base to see if it is cooked. You might need to keep cooking for a minute longer.
Step 8: Serve Your Pizza
Remove the pizza from the Gas Grill.
Slide onto a heatproof surface and cut into portions.
While you are stuffing your face, roll out and prepare another Pizza!
Step 9: For a Bit of Fun
Need a good laugh?
Here is a video I did on the technique many years ago!
Barbecue Challenge
This is an entry in the
Barbecue Challenge
    • Sew Tough Challenge
      Sew Tough Challenge
    • Planter Challenge
      Planter Challenge
    • Classroom Science Contest
    14 Discussions
    StefanoB76
    5 days ago
    Perché usate la passata Val Verde, che è australiana, e fa finta di essere italiana ?
    Usate almeno i vostri prodotti e venite in Italia a mangiare roba buona.
    E poi denigriamo i Cinesi perché copiano le cose !
    UrbanGrillerStefanoB76
    Reply 5 days ago
    I had to use Google Translate to read your questions.
    "Why do you use the past Val Verde, which is Australian, and pretends to be Italian?
    Use at least your products and come to Italy to eat good stuff.
    And then we denigrate the Chinese because they copy things!"
    I use the Val Verde Passata because I'm in Australia and that is what our supermarkets have, back on the farm we would make our own once a year from fresh tomatoes. I'd love to go to Italy and enjoy its food one day, I just need to win the lotto first, so I can buy a ticket.
    StefanoB76UrbanGriller
    Reply 3 days ago
    Non è prodotto in Italia ma con pomodori, forse, italiani.
    Dal 2016, in Australia, ci sono dazi per le importazioni dei prodotti alimentari italiani.
    Per fare la passata di pomodoro si usa la varietà " butaline ", la più comune delle varietà di pomodoro, penso che le abbiate anche voi e che siano buone uguale.
    Sono arrabbiato solo perché una qualunque azienda, in qualunque parte del mondo, applica una bandierina verde, bianca e rossa ed il prodotto assume subito un altro valore.
    Nella mia zona è cresciuta una forte produzione di kiwi, sui mercati si vendono come prodotti in Piemonte e non si mette una bandierina come provenienti da New Zeland.
    Comunque smettiamola qua, spero che col tuo sistema tu riesca a mangiare una buona pizza, a prescindere da cosa ci metti sopra.
    Scusa se scrivo in italiano, ma così riesco a dare un senso al mio discorso, poi ci penserà Google translate a farlo diventare ridicolo.
    Buona giornata dall' altra parte del mondo.
    Reply 4 days ago
    I had a look at my bottle at home, Val Verde is an Australian Family Company but the Sauce is Made in Italy
    UrbanGrillerfthies
    Reply 5 days ago
    Yes! I run BBQ Cooking classes here in Perth Western Australia, "Always Play with your Food" is the company motto (I just use it to annoy my mum).
    pmillho
    5 days ago
    This looks awesome I'd love to try it. I don't have a bread mixer or a gas grill though. Can the dough be made without the mixer? Have you ever tried doing this on a charcoal grill?
    Also I don't recall seeing passata in the grocery stores here in the US, could we just substitute a good quality marinara or pizza sauce?
    UrbanGrillerpmillho
    Reply 5 days ago
    Passata is just the plain form, marinara and pizza are the same as Passata, just with basil and garlic added.
    Yes it can be cooked on a charcoal grill with a good hot fire. The mixer just makes life easy, you can hand-make the dough if you need to, I've done it many times while camping
    stumitchpmillho
    Reply 5 days ago
    This would be great on a grill with charcoal... it reaches nice high temps pretty quickly. The bread maker you can find at most thrift and second hand stores. So many people buy bread machines with good intentions... Thanks for the great 'ible!
    ciscomancerpmillho
    Reply 5 days ago
    Our local grocer (Kroger) sells pre-made crust in a bag. You could also do the roll out kind in the tube. Some local pizza places will also sell dough in the raw.
    drlexluthor
    5 days ago
    From Pizza maker to pizza maker, I can't wait to try your method! IT LOOKS AMAZING! Q4U: Have you tried it with pizza screens? Do you know a good Chicago style as well?
    UrbanGrillerdrlexluthor
    Reply 5 days ago
    I don't have a pizza screen but I see no reason why it would not work well
    MaraCreates
    5 days ago
    This looks so good, love a good pizza!
    jessyratfink
    16 days ago
    That looks amazing! Now I sorta want to try this on my smoker :D
