Introduction: Altoids Tin Lunchbox
this mini lunch box is perfect for packing snacks for road trips and such.
Step 1: Materials
altoids tin
2 beads
hot glue gun
hot glue sticks
paperclip
wire cutter (not pictured)
2 beads
hot glue gun
hot glue sticks
paperclip
Step 2: Hot Glue
put 2 dots of hot glue on top of tin
Step 3: Beads
stick a bead on top of each dot of glue
Step 4: Handle
make a handle out of a paperclip that you will stick in the middle of the 2 beads clip excess off with wire cutters
Step 5: Stick It In
stick in the handle (add fresh hot glue if needed. just squirt down bead)
dood01 says: you could also solder it
Step 6: Packing
i putt a napkin in the bottom of my tin to keep noise reduced then i filled it with cashews and 2 cheese crackers
Step 7: Done!
and your done. i hope you have enjoyed my first instructable.
