Introduction: Fast Robot That Can Carry Five Lbs
this is what it should look like at the beginning
Step 1: Our Initial and the Changes
Step 2: Materials Needed
flat the top
add one more wheel
two more 60 gears
4 kept nuts
4 spacers
4 flat bearing
8 allen screw
battery holder
4 collers
hex rench
2 open ended rench
2 shafts
Step 3: After You Add All That.
it should look like this
Step 4: Sled
make a sled
you will need a
13 keps locks
13 screws 3/8
a 5 hole angle bar
a 9 hole angle bar
4 bearing blocks
Step 5: Your Sled
Step 6:
you should have someinght that looks like this
Step 7:
it can carry 5-7 lbs
Step 8: This Is How It Should Run
Step 9:
Step 10: Why We Chose It
We chose this design because it seemed easy to do with he materials we were given. all we had to do was flatten the top and replace a few things.
Step 11: Robot Info
the in put is 115.8
the output is 0.33
torque is also 0.33
the gear ratio is 5:1 and 1:1
there is no theoretical speed
nor actual speed
