Introduction: Pvc Tripod for Camera
Since i was in need for a tripod to work, and there is no photography store close, i decided to work with some materials i found at home.
- 3 3/4 pvc about 12" long (can be longer if you wish)
- 2 elbows 90°and 1 45°
- 1 T
- 1 threaded coupling
- a screw about 2" with nut.
- black spray
You can see is pretty easy to asemble, light and cheap (no more than US 5.00)
i am sure is not as good as a profesional one, but it works pretty good.
Step 1: PVC Parts for the Tripod
I had three 3/4 PVC pipe, 12" long with two 90° elbow and one 45°. also have a T and a threaded coupling (because one of pvc was a little short than the others).
Step 2: Put the Pvc Parts Together
I put them just with some glue, but they can fit fine with pressure.
Step 3: Drill a Hole in to the PVC T
I made a hole in the pvc T, insert a 1/4" screw with nut and thight them just enough.
Step 4: Final Step
I use some black spray to give it a better look, and thats it.
