Introduction: Iphone Controlled Led Without a Computer or Internet
I build a small webside running on the arduino with ethernet I/O using HTML and a little bit of css.
When sending a HTTP request the script reads the request and gets a command from it.
You don't need internet, only a working network and a computer of smartphone connected to the same network.
Step 1: The Parts
Parts:
1 arduino,
1 ethernet shield, or a Sparkfun Pro Ethernet (not for sale anymore....)
1 LED connected to digital pin 9 and GND,
1 network-cable
working network
Step 2: The Circuit
easy:
just plug the led (+) into the digitale pin 9 and the short one to GND.
And connect the arduino to the network with a networkcable.
Step 3: The Code
just upload this code to the arduino:
/* IPhone controlled LED
Turns on and off a LED connected to a digital pin, via a computer or
IPhone (or even a android device) without using internet.
combined examples:
Examples > Ethernet > Webserver and Examples > Digital > BlinkWithoutDelay
The circuit:
* LED attached from pin 9 to ground.
* EthernetShield using pins 10,11,12,13.
created mar 2013
by Floris
floris (at) deboktor.nl
This example code is in the public domain.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,30,178); //choose a IPadress so you can easily find it on your computer
EthernetServer server(80);
String currentLine = "";
char Command[100];
int page = 2;
int prevpage = page;
long previousMillis = 0;
long interval = 500;
int ledState = LOW;
boolean PageUpdated = false;
int LedPin = 9;
void setup() {
pinMode(LedPin, OUTPUT);
currentLine.reserve(256);
Ethernet.begin(mac, ip);
server.begin();
digitalWrite(LedPin,LOW);
void loop() {
EthernetClient client = server.available();
if (client) {
boolean currentLineIsBlank = true;
boolean ValidCommand = false;
int i = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
currentLine += c;
if (!ValidCommand){
Command[i] = c;
i++;
if (c == '\n') {
currentLine = "";
if ( currentLine.endsWith("HTTP/1.1")) { //line format is like: GET /?s=1 HTTP/1.1 or GET /favicon.ico HTTP/1.1
ValidCommand = true;
if (Command[5]-'?'==0){ //if the 5th karakter is ?
if (Command[6]-'s'==0){ //then a s
prevpage = page; //to prevent giving a strange command
page = Command[8]-'0';//after the ?= is the actual command
if(page!=1 && page !=2 && page!=3){ //1 = on, 2 = of, 3 = flashing
page = prevpage;
if (c == '\n' && currentLineIsBlank) {
delay(10);
client.print("<!DOCTYPE HTML>\n");
client.print("<HTML>\n<HEAD>\n");
client.print("<TITLE>led-online</TITLE>\n");
client.print("<meta name='viewport' content='user-scalable=yes, width=device-width'>");
client.print("<style type='text/css'>\n");
client.print("body {\n background-color: white; \n color: #222; \n font-family: Helvetica; \n margin: 0; \n padding: 0\n }\n");
client.print("div#button_On {\n background-color: blue; \n border-bottom: 1px solid #666; \n color: #222; \n display: block; \n font-color: black; \n font-size: 14px; \n font-weight: bold; \n padding: 10px 0; \n text-align: center; \n text-decoration: none\n }\n\n");
client.print("div#button_Off {\n background-color: #ccc; \n border-bottom: 1px solid #666; \n color: #222; \n display: block; \n font-color: black; \n font-size: 14px; \n font-weight: bold; \n padding: 10px 0; \n text-align: center; \n text-decoration: none\n }\n\n");
client.print("a {\n text-decoration: none;\n }");
client.print("\n </style>\n");
if ((page!=0)&&(!PageUpdated)){//1 sec after a command refresh the page
client.print("<META HTTP-EQUIV='refresh' CONTENT='1; URL=/'>\n");
PageUpdated = true;
else{ //normally once everyy 10 sec a page update
client.print("<META HTTP-EQUIV='refresh' CONTENT='10; URL=/'>\n");
client.print("</HEAD>\n");
client.print("<BODY>\n\n");
client.print("<a href='/?s=1'>\n");
if (page==1){
client.print("<div id='button_On'>");
else{
client.print("<div id='button_Off'>");
client.print("LED ON");
client.print("</div>\n");
client.print("</a>\n");
client.print("<a href='/?s=2'>\n");
if (page==2){
else{
client.print("LED OFF");
client.print("<a href='/?s=3'>\n");
if (page==3){
else{
client.print("LED FLASHING");
break;
if (c == '\n') {
else if (c != '\r') {
currentLineIsBlank = false;
delay(1);
client.stop();
switch (page){
case 1:
digitalWrite(LedPin,HIGH);
break;
case 2:
break;
case 3:
digitalWrite(LedPin, ledState);
if(millis() - previousMillis > interval) {
previousMillis = millis();
if (ledState == LOW)
ledState = HIGH;
else
ledState = LOW;
break;
combined examples:
The circuit:
created mar 2013
by Floris
#include <SPI.h>
byte mac[] = {
char Command[100];
int page = 2;
int ledState = LOW;
int LedPin = 9;
void setup() {
server.begin();
void loop() {
if (client) {
int i = 0;
currentLine += c;
if (!ValidCommand){
Command[i] = c;
i++;
if (c == '\n') {
currentLine = "";
page = prevpage;
delay(10);
PageUpdated = true;
if (page==1){
else{
if (page==2){
else{
if (page==3){
else{
break;
if (c == '\n') {
delay(1);
client.stop();
switch (page){
case 1:
break;
case 2:
break;
case 3:
ledState = HIGH;
else
ledState = LOW;
break;
Step 4: Finally
go the the IP adres asigned in the code on a smartphone or computer connected to the same network as the arduino.
a 3 button page will appear.
Just click on one of the buttons and see whats happening......
