Introduction: Knex Gun With Magazine
About: Shhhh I'm typing.
This is my knex gun that i made.oh ya and this is my first instructable.
Step 1: The Butt
this is the butt pretty easy part
Step 2: Barrel and Magazine
This step might be a little confusing but i think its pretty easy.oh ya and if you already have looswires magazine made it will be easy and i give some credit to loose wire on this part.
Step 3: Side Panels and Pump and Firing Pin
pretty easy step just the side panels and the pump and the firing pin
Step 4: Putting It Together
pic 1: slide the side panel over the magazine
pic 2: connect the side panel to the magazine
pic 3:the rubber bands goes on there
pic 4 : the pump on the firing pin
pic 5:where the rubber bands goes on
pic 6:connect the butt to the barrel and side pannel
Step 5: Rubber Bands
ok i use the thick strecthy kind but you can use what ever you want.
ok first you take the blue rod off the magazine on the side and put the rubber band around the white connectors. next take the butt off. now put the firing pin and pump in the barrel.then put your rubber band around the fring pin.put a second rubber band on the pump and put it around the bottom part of the white connectors.
Step 6: Loading and Firing
first you put the blue rods in the magazine. Then you pull the pump back and put the trigger into place.then just keep repeating.
Step 7: Extra Side Pannels
this step is optional but makes it like unbreakable and makes it looks cooler
sorry for the bad instructions on this step
