Introduction: K'nex Movie Angle
a useful k'nex built tool to allow you to watch video on you electronics.
works for psp, phones and many other electronics
Step 1: The Parts
The parts it takes it build it
only 37 parts
parts shown below
only 37 parts
parts shown below
Step 2: Make This
This part is easy take 2 yellow rods and two one pin connectors as shown in the picture and connect them as shown
Step 3: Make This
take two corner red connectors, one blue rod , 2 green connectors and 2 black connectors with the ball fitting at one end
connect all the pieces as shown below
Step 4: Connect These
take two white rods and one yellow connector and put them together with the piece you just made in step 3
connect the rods and yellow connector as shown below
Step 5: Make This
Take two red corner connectors, one blue rod, 2 green connectors and 2 black connectors with the ball at one end
connect all the pieces as shown in the picture below
Step 6: Connect These
take two more white rods and connect them to the red corner connectors as shown in the picture below
Step 7: Connect These
Now take the piece from the last step and the piece from step 4 and connect them through the ball fittings and the ball
connect the pieces as shown in the image below
This will allow the final piece to bend
Step 8: Add These
Add the Two yellow connectors that you made in the start to the red corners through the hole in the red corner connectors
make sure you add the yellow rods to the side that is connected to the yellow connector in the middle
Step 9: Make This X2
make a blue rod connected to 2 red corner connectors on both sides of the blue rod
do this twice
make this piece as shown below in the picture
do this twice
Step 10: Connect These
take your body piece that you made in step 8 and connect the two pieces you just made in the last step
connect the pieces as shown in the second picture
Step 11: Make These
okay your almost done
now make the piece as shown in the picture below out of 2 white rods and 2 blue end caps
Step 12: Add These
Now take the main body piece and add the white rods with blue end caps to the bottom red corner connectors through the holes
connect the as shown in the picture 2
Step 13: Your Done
okay last thing to do is to secure the pieces you made in step 11 with 2 black extensions
check the parts picture for those pieces
Connect the last pieces as shown below
