Introduction: Laser Light Show
a cheap and easy why to make a laser light show. the video shoes what it will look like when we are done
Step 1: What You Need
what you will need
1.laser (duh)
2.old speaker
3.wire hanger
4.cd
5.rubber/vinyl glove /condom
6.any round thing that will fit you speaker
7.speaker wire
8.rubber band
9.music
tools
1.tape
2.pliers
3.glue
1.laser (duh)
2.old speaker
3.wire hanger
4.cd
7.speaker wire
8.rubber band
9.music
tools
1.tape
2.pliers
3.glue
Step 2: The Speaker
ok you got your stuff now we need to make the laser light show!!! first things first testing the speaker.
rip your speaker out and cut the two wires on the side about 1inch from the speaker leaving some wire to connect to the speaker wire.ok heres where the tape comes in handy strip off the ends of the two wires of the speaker and the two wires of the speaker wire.connect the ends together and tape them up. now plug in the speaker to your nearest music source and test the speaker turn up the volume to see if the speaker can handle it. to the next step
Step 3: The Round Thing
now we got the speaker working now we need to make it air tight.glue the rund object to your speaker and let dry
Step 4: The Glove
now your round thing is glued to your speaker. next take your glove/condom and cout it to the shape of you round object leaving it a inch bigger around the edge of the round object. next take your rubber band and strech it around the glove/condom and tighten the glove/condom so you can hit it and it will sound like a drum.next take your cd and cut a small square and glue it in the middle of the glove/condom.now you ready for the next step
Step 5: Hanger Time
unbend your hanger (this is the part you get to use you cool pliers).now bend one end into a circle this is the bottom.next bend the othe end to hold you laser.almost done
Step 6: Laser
now put your laser on the hanger.next put the speaker in the bottom circle of the hanger and bend the laser so it bounces off the cd peace and onto a wall or celing.
Step 7: The Show
now just turn on the laser and your music and rock out with style
