Introduction: Lego Flashdrive
supplies
1. flash drive
2. legos
3. hot glue gun
4. dremel and bits
*first you take your USB flash drive apart, it might be hot glued in so give it a little tug.
*next take a thick 6x2 lego depending on size of flash drive and the same size thinner Lego next use a dremel and the bit you think will work best then grin a wide enough and long enough indention in the thick lego .
*then you hot glue the flash drive in and put the thin lego on
1. flash drive
2. legos
3. hot glue gun
4. dremel and bits
