Introduction: Lego Gun
Step 1: Peices You Will Need
Step 2: Steo 1
get the 12 stud flat and the 3 stud flat and place the 3 one at the end of the 12. add the brick with the hole and the 2 brick with a hole on the 3 stud
Step 3:
Step 4:
add the 8 stud flat on the bottom across the 12 stud
Step 5:
get the elastic band and thread it through the hole thingy then put the brick with the pole coming of it on the 8 stud flat facing inward
Step 6:
then do the same on the other side this should holdd the band nice
Step 7:
get the 6 stud flat and put it evenly on the botom
Step 8:
get the 8 stud singular flat and put it on the 8 stud double
Step 9:
Step 10:
add the corners on the edge
Step 11:
add the 2 stud things on the sides
Step 12:
add the other 8 stud flat behind the 2 studs
Step 13:
like this
Step 14:
add the long smooth things on to the 12 stud brick add the smooth square on the hole thing
Step 15: To Fire
pull the hole thing back till te edge of the smooth thing then let go or just chuck the model at youre brother or sister
Step 16:
oh and this is the bullet if you struggle to make this i will try and answer your questions bye
