Introduction: Lego Wipeout
welcome to wipeout
Step 1: J&j's "stand"
make the stand high but. low enogh to see the wipeout course add a veiwing area behind them (as seen in photo)
be sure to add mini figures of j&j , a director , and a camera man
Step 2: Bannana Split
the bannana split is a wobbily slippery obstical that rocks back and forth make a turning piece and then an elbow going down atach a platform (look at pic for best results)
Step 3: Punching Wall
very simple make a wall with holes in it and add flick missils with red stud the on end
Step 4: Unfortunate Fall
like all wipeout courses right after climbing up a stair case (or ladder) something will hit you off for this i put a raised brick (with a hole in it ) stuck a stick (with a disk atached to the end) through the hole and and put a stopper on the end
Step 5: Pre Big Ball Wipeout
Step 6:
this one hurts! put a post and put a moving piece through the post and atach a brick with smacker on the end (see pic for help)
Step 7:
Step 8:
Step 9: Big Balls
Step 10:
this one is a wipeout classic first make your big balls
Step 11: Gears
Step 12:
Step 13:
Step 14:
Step 15:
Step 16:
Step 17:
now if you didint pay attention to the notes your brobaly lost , go back and read all notes instructables has a great note system making my job easier its also more fun to foliow along as i buit it
anyhow this gear system should work with however many big balls you like but , take note that the more big balls you have the harder it is to turn the gears
Step 18:
Step 19: The Tilty Bridge
the tilty bridge is simply a platform with 2 holes on both side (longways!) atached to 2 raised connecters (see pic)
Step 20: Catapult
a simple elbow atached to a platform with a spot for a person to sit
Step 21: Winnnnnnnnnnersssss Circle
you won!!!! it is a simple square platform with a large gra circle and a smaal red circle in the middle
Step 22: End
thanks for looking at my instructible have a fun time building
Step 23:
like to give credit to my sister and my freind (same as winston)
