Introduction: Basic Live Trap for Rabbits, Squirrels and Other Beasts
For one reason or another I have found myself in need of a easy live trap for various small animals. This includes furry garden invaders, escaped pets, unwanted attic inhabitants and perhaps the holiday being know as the easter bunny.
Step 1: The Materials
Materials needed
- Wood,
The dimensions of the the cut pieces are below.
(2) 0.75"x6"x16" SIDE
(2) 0.75"X8"X16" TOP/BOTTOM
(1) 0.75"X6"X6" DOOR
(1) 0.75"X8"X8" BACK
I would recommend using treated lumber (fence planks are rough and cheap).
I used plywood that I had left over in my garage, I don't recommend it. (Nailing into the end of plywood is a real pain).
- Fish line, paracord, wire,
-Really any thin strong line with little stretch,
-Small nails or wood screws-
1.25" long should be fine
-Hinge
I reused a hinge from an amorie door, I spring loaded self closing hinge would be a good revision on this part.
-Rubber band
any kind of elastic could work for this
Step 2: Pookie
ok so the idea is a big wooden box with a door that swings shut behind the beast as it eats the tasty treat at the end of the tunnel.
so first things first you need to make the box. The way I like to do this is to first nail the two sides onto the bottom Aka nail through the bottom and into the side of the pieces of wood that make up the sides of the trap. Make sure to drill pilot holes before you nail or screw. I used three nails for each joint, one in the middle and one at each end. After you get both of the side onto the bottom its time to add the back. line the back up with the two sides and the bottom and nail it on.
Step 3: Now for the Top
ah yes the top. Im not really sure why I made a step for the top exclusively, but I did. Any way add the top the same way you did the back and nail it on. The top will need to have two holes cut in it and two holes chiseled in it but we can do that later.
Step 4: The Door
The door will be swinging closed to trap the animal, so it needs to be as tight as possible while still being able to swing freely. cut it a bit more than 6"x6" and then sand it down till its perfect. The door is mounted using a small hinge. I used a hinge from a jewelry box and screwed it on so it can only open in.
Step 5: The Mechanics
the top of the trap now needs several changes and addition. first you need to drill a hole that if the door is folded flat against the inside of the trap the hole will hit it. This is where the cord will go through to hold the door up when the trap is set. next about 4 or 5inches from the back make a rectangular, i drilled the basics shape out and then used a chisel to straighten it up. this hole is where the trigger will be placed. finally midway between these two holes you need to chisel two rectangular holes about half way through the wood. These need to be beside each other and a little bit bigger than the dimensions of the arms that hold the seesaw.
Step 6: All Else
all that remains to be done is assembling the see saw and trigger. The first thing you need to do is to cut two peices of wood about 2 inches wide and 5-6 inches long, these will be the arms. Insert these peices in the two holes you chiseld out so that they run parallel to each other put wood glue or liquid nail arounf the base of the two arms to hole them in the indentions. next use a long thin peice of wood that will fit in the gap between the two arms this pecie should be about 8-10 inches long and should be very thin but strong i actually used a peice of metal tube that i had flattened out with a seldge hammer. This long piece needs on hole drilled in the middle where it crosses the arms this is where the axle will go. It also needs two holes drilled in both ends .
Step 7: Ok So I Guess There More
now use a small nail that you can insert through the two arms and the middle piece, this will be the axle. tie a piece of the fishing line or cord onto the end of the middle piece and connect it to the door through the circular hole in the top of the trap. The piece should be long enough that when the see saw it all the way up the door is pulled all the way up against the top of the inside of the trap. On the other end of the middle piece attach a piece of sheet metal bent into the the shape of a L with an added on tail or like one segment of a lightning bolt. Use a piece of fishing line to connect the sheet metal to the middle piece just tie it through the holes drilled in the piece and another hole drilled in the sheet metal. The sheet metal needs to be able to be hooked on the underside of the top of the trap while the door is brought all the way up so adjust the length accordingly.
