Introduction: Tiny Shooter
One can make this in <15 minutes with stuff around
Take safety precautions while making and using the same as it shoots really far the ammo
Step 1: In Action
Step 2: Materials
1. lollipop stick/tubing/ empty ball-point refill
2. paper clip
3. thin elastic rubber band
4. wire
5. pin
Needle nose plier to shape and cut the wire
Step 3: Getting Started
Take the paper clip, open it and make the plunger as shown
Shape a piece of wire to make the gun end
Step 4: Mechanism
Cut the plunger using the pliers
Tie the elastic band to get a smaller rubber band
Cut the lollipop tube to half, making sure it is bigger than our plunger
Make a tiny hole in the area shown on the tube
For holding the trigger make a small loop in the gun end wire by rolling it around a paper pin
Step 5: Mechanism Contd.
Pass the rubber band in the plunger end
Make a trigger by rolling the wire with a loop in the center
Tie up the gun-end wire as shown
Step 6: Trigger Mechanism
Making the trigger mechanism is a bit tricky
Use a pin to hold the trigger in position as shown below
This trigger should be able to hold the plunger when the rubber band mechanism is pulled.
Step 7: Assembly
Take a bit of wire and securely tie to make kind of magazine
this will serve to hold the rubber mechanism in place
Assemble as indicated and pull to arm the shooter
Step 8: Finishing Touches
The trigger needs to be pressed in the aperture so as to hold the plunger when armed,
when pulled it can shoot your ammo
You can also use a tiny rubber band to press the trigger in place (not shown here)
Use your imagination and design other accessories like gun sights, handles etc.
28 Comments
9 years ago on Introduction
good idea..
10 years ago on Introduction
What lollipop brand is that? And where did you get the elastic from? This is a very entertaining, time killing project. I love it! :)
Not sure about the brand, any hollow tube, even from a refill can be used. The elastic was from a tag, you can use a good rubber-band instead, the ones that last a bit longer
tx
10 years ago on Step 2
Im gonna use more paperclips instead of wires
Reply 10 years ago on Step 2
sure, it will make it make more sturdier
Yeah so its sturdier, its not that i dont have wires or something
i also made one and it shoots really fast.thanks for the idea
That's very cool
You should enter this in the miniatures contest!
...did you use final fantasy 7 music in the video? :)
11 years ago on Introduction
I'm going to make my own, but a bit bigger, using a pen tube... It's more resourceful in my house than a lollipop stick.
I did that with a pen tube, but a different design, the pen tube soon broke, would recommend reinforcing the end that will take the rest of the force of the plunger
Reply 11 years ago on Introduction
do take care when target practicing :)
Ha. Will do! ;)
Well documented! Good job. I like the trigger.
Thanks,
Even with a little mod, one can add a magazine to hold tiny pellets! on the top for more fun
can youpost how to make the magzine sorry if i it to late
Hi
its just a rectangular box with losely held 'ammo" which loads itself by gravity, when fitted over the barrel top.
Hope this helps as I am out of my home to post the same in action
