Introduction: Loom Band "ribbon"
this here is an autism ribbon
but you can do any color you want ...
Step 1: Loom Position
make sure your loom is just as shown in this picture
Step 2: Choose Your Color
first choose your colors
in my case I'll be using pink for a breast cancer awareness ribbon
Step 3: Start Placing Your Rubber Bands
we are going to use double bands through this hole process!!
1.take double bands and place the from the middle peg to the left peg.
2.now take double bands and go up three times.
3.take double bands and go from the left peg to the middle peg.
do the same for the right side
"MAKE SURE THEY ARE ALL DOUBLE"!
4.now do the same for the other side
&& it should look like my fourth picture :)
Step 4: Placing the Bottom Bands
this part you can do it how ever long you want but I like the size I make because it looks better to me..but its up to you ;)
1.you will be placing double bands from the middle peg to the upper right peg.
2.now from the right peg you will go down five times or more or less how ever you want it in my case it will be five..
do the same thing for the other side
3.start back at the middle peg from the middle peg to your upper left .
4.now go down five times
it should look like my fourth picture ;)
Step 5: Placing Cap Bands
on the bottom of both ends you will be placing cap bands
1.turn your loom around "make sure it looks like the first picture"!!
2.take your hook and wrap ONE band around 3 times to make four loops and it should look like my second picture .
3.now place your first cap band on the last peg where your bands end
do the same for the other end
Step 6: Time to Loop
1.push back your cap band and grab the bottom two bands then loop forward until it looks like the third picture
2.now go from the left peg to the middle then the right peg to the middle it should look like my fourth picture
3.for this part you have to be carefully since there is a lot of bands go behind all the bands and grab the top two bands "these should go to the top left as shown in my fifth picture"
4.loop all the way up and from your last peg loop from your left to the middle final peg
"it should look like my last photo"
Step 7: Last Step Before Pulling It Off the Loom
1.put your hook through all the rubber bands as shown in the first photo
2.place double bands on your hook
3.loop it through so it looks like the third photo
4.create a slip knot
pull tight
Step 8: Now Pull It Off the Loom and DONE
and it should look like this
hope you guys like it !!
