Introduction: Max Force Shadow Hawk Mod Add Trigger
hi, Jaxx Pacific Max Force Shadowhawk is a very cool gun. but. it had no trigger.very sad,so i search on internet add a trigger on.then find an brilliant guy name Psyk, i just follow him and make a little change. thanks for his idea first.
Step 1: Cut Priming Rod
cut the priming rod as two piece at mark in pic1, then the grip can return to the front position after load
then use eva foam make two small things like pic 2 and 3,it can avoid priming rod up&down shake and strike grip too heavy after fire.
sorry ,i forgot take photo after combine ha.
Step 2: Trigger
use the metal part (ikea furniture connecting piece)and nerf longshot front gun inside part make the L-bracket.
Step 3: Cut to Install Trigger
cut the gun body trace the line i mark on it (pic 1 ang 2)and other parts (pic 3)
intall trigger and spring .
almost done.
Step 4: Done
i forgot take pic of the priming rod,it need cut a notch also.
the notch can lock with the L-bracket loading .
finish.........
shot spitwads like a real sniper hahaha, very funny and amazing .thxxxxxxx for ur read
