Introduction: Mepalm's Mini Deadly Spray Grenade
A small grenade i made to pass the time. Very efficient to pieces only 12 pieces.
Needs one exotic but not necessary. This is my first instructable...yadada. Whatever. Feel free to say anything. I would like contructive ones though. This is not a copy of someone elses. This is V2.
No posting of this without telling me first!
Step 1: Pieces YOU Will Need
1 red connector
2 white connectors
1 grey connector
1 "possibly exotic" black connector/rod in 1!
6 spacers
1 yellow rod
2 rubber bands
2 white connectors
1 grey connector
6 spacers
1 yellow rod
2 rubber bands
Step 2: Step 1!
Simple and easy just follow the picture.
For you that can't see my hi rez picts.....
Attach the red connector middle slot on the yellow rod ends.
Slip in a white connector.
Step 3: Step 2
Slip on the grey connector, not clipped on!
and 6 spacers
and 6 spacers
Step 4: Last Step
put on the other white connecter at the end and put on the black connector so that it is loose but secures its position. And put on the rubberbands OPPOSITE of each other on the 2 connectors so it doesn't blast out in your face. I used big rubber bands so i doubled back so use small ones to avoid hassle.
Step 5: Ending
This is not all the debris. I just picked them up after the boom. The shrapnel was like 15 m away with right rubberbands like mine so i couln't take picts.
twist and pull of the clip on end...I'M sure you'll find out how. Its on the extra picture and remove the rod. Then throw! Bam explosion. It doesn't look like a real grenade but it does the job. Mod it if you want but give me a rating first.
