Fix a Flat Tyre - Tire the Easy Way With a Mini Compressor in the Car Boot
Intro: Fix a Flat Tyre - Tire the Easy Way With a Mini Compressor in the Car Boot
This is a very simple general suggestion I found many drivers are not familiar with. Keep a mini compressor (cost about 10-20$) in your car boot. When you have a flat tyre use the mini compressor to pump the tyre up and drive to the nearest garage to get it repaired. You'll have to go to the garage anyway so you might as well save yourself the hassle of changing the wheel. Careful!!! Local laws may forbid driving with a punctured tyre.
STEP 1:
Occasionally you'll get a flat tyre. The first thought is to change the tyre and then go to the garage to get it repaired. Well there is an easier and less laborious way.......
STEP 2:
Always keep a mini compressor (cost about 10-20$)in your car boot.
The compressor will surely come with the manufacturer's set of instructions and these are easy to follow.
STEP 3:
Insert the mini compressor plug into the cigarette lighter socket.
STEP 4:
Pump the tyre up to the required pressure.
STEP 5:
Drive to the nearest garage to get the tyre repaired.
8 Comments
autoczesci 11 years ago
nlsnglls 11 years ago
I hope I was nice ;-)
georion 12 years ago
if its not a "Slow" leak,,,,this is a waste of time
fast leak? go ahead and put the spare on
have used your way many times BUT
only on "slow" leaks
robz40 12 years ago
picky1969 13 years ago
kukopia 13 years ago
robz40 13 years ago
But as stated "This is a very simple general suggestion I found many drivers are not familiar with."
It is a simple trick I believe every driver should be aware of as I found out by helping people out a few times
lukeyj15 15 years ago
