Introduction: Mini Knex Launcher
launches knex into the air, also could be a weapon
There is supposed to be a rubber band at the end of it
Step 1: The Pieces You Will Need
There are three white connectors, twenty-nine orange connectors, two tan connectors, nine gray rods, two white rods, and one yellow rod
Step 2: First Make the Shell
start with the white piece and snap all but one gray rod on it like so.
Step 3: The Pattern
now arrange 26 orange pieces in the middle in any pattern, it does not matter. Just make sure it attatches to its opposite.
Step 4: Attatch the Other White Piece
This is the hard part, you may want to use a hammer, observe four of the gray rods have been lifted up so the whit connector can fit
Step 5: Now It Is Time for the Firing Rod
make the rod then put the rubberband through the rod. Make sure the rubber band is in the right position.
Step 6: This Is the Final Step
All you need to do is attatch the firing rod to the end of the shell with two tan connectors. MISTAKE! there is supposed to be a rubber band on the firing rod, in the same place as before.
Just stick in the bullet and pull the yellow rod.
Step 7: Bullets
These are some of the bullets you can make
