Introduction: Mini Sculpting Table
i have broke my hard disk brushless motor when i want to make grinder and some time i make small sculpt, so i decide to make small turn table.
you will need :
1. broken HDD brushless motor
2. i used six unreadable cd / dvd
3. epoxy glue
4. reuseable adhesive for poster
tool i used :
1. torx screw driver
2. solder.
3. quick release clamp
you will need :
3. epoxy glue
tool i used :
2. solder.
Step 1: Disassemble Motor
first, you need to disassemble hard disk motor disk ( sorry, mine has been disassemble from hard disk, so you need release your motor from hard disk first)
Step 2: Make Base
clamp several cd / dvd , i used six cd /dvd (broken one, prefer)
Step 3: Solrdered Cd/dvd
i use solder to weld cd/dvd in the outer part, make some line with hot solder tip until melt plastic ( i make 10 point).
you can glue sandwich, if you want. i weld disk because this quick and strong enough for me.
Step 4: Add Motor to Base
now glue motor with epoxy to cd base
Step 5: Final
get disk plate on motor with unreuseable adhesive (i do this because i want disk plate able to quick release), or you can use double tape, hot glue etc
