Introduction: Music Controlled LED
this instructable will show you how to make an easy blinking LED to music.
you can try it whit normal lamp but the effect is better whit LEDs its easy to make it.I made it after 30 minutes. and after the effect is awesome
Step 1: Materials That You Will Need
you will need:
materials:
1×tip 31 transistor
2×led
1×6v transformer
some wire
tools:
soldering iron
solderer
wire cutter
scissor
materials:
1×tip 31 transistor
2×led
1×6v transformer
some wire
tools:
soldering iron
solderer
wire cutter
scissor
Step 2: Leds
to the effect is better connect the led in serial connection. they going to blinking much better
Step 3: Transistor
the circuit is based on the tip31 transistor you have to connect the music left to the left side of the transistor
connect the wire of the leds to the middle of the transistor
connect the music right and the negative pole of the power supply to the right side to the transistor
Step 4: Connectig to the Music (whit Rca)
grab the to wire for the music and connect the right side to the middle of the right plug's middle
the left side of the music connected to the left side rca to the middle of it.
Step 5: Placing
cut three holes on a box:
2 for the leds
1 for the wires
after fix it whit some duct tape
2 for the leds
1 for the wires
