Introduction: Musical Beat Thief
No we're not stealing musical beats of any kind but we are going to make leds flash to music using a joule thief circuit with a slight modifacation
Step 1: Finding Parts
you could buy parts or salvage them like I did , but anyways you need :
toroid bead
3.5mm audio jack
thin wire
led (any colour)
270 ohms resistor (red,violet,brown,gold)
s9014 transistor or equivalent
stripboard (optional)
( http://www.datasheetcatalog.org/datasheet/auk/STS9014.pdf ) datasheet for the transistor.
toroid bead
3.5mm audio jack
thin wire
led (any colour)
Step 2: Construction
First off I would start with the toroid you need really thin wire with quite thin insulation, you want about 9-11 wraps around the toroid bead. After that you should solder two different wires from opposing ends together, so now you should have 3 wires coming out of the bead the two you just soldered are now the + in wires,now take one of the remaining wires and solder the resistor to it then solder the resistor to the middle pin of the transistor , take the last wire from the toroid and solder it to the collector of the transistor.
Solder the + leg of the led to the collector on the transistor and the - leg to the emitter.
Also add a length of wire to the - leg of the led for the ground wire.
Then solder the ground wire to the 3.5mm jack and the positive to the left or right channel.
Step 3: Finished
Now plug it into a music sorce and hope for the best.
I've found this wont work with some mp3 players with low volume but it works on laptops and tv's
they also make great badges and if you add another 3.5mm jack you can listen and watch it flash although i havent tried it and it might distort you music a bit.
If you want it to flash more lower the resistor value, I have mine so it flashes to singing but if you put in a higher ohm resistor you could make it only flash to bass.
Another idea is to make two and have one for music left ouputt,and one for music right output i imagen that could be quite fun to watch
Doesnt work ? :
try turning up the volume on the music sorce
check connections on all soldered parts
make sure you havent put the transistor or the led the wrong way around
Doesnt work ? :
