Introduction: Nerf Mavric Super Powerd
This is instructabule is for the Nerf mavric, it increases loading speed and power. and a dart mod
* DISCLAIMER:
I am not responsibly for any or a injure, or involvement with the law on your part, so think safety! Be sure to where proper protection and be sure to secure all protection
* DISCLAIMER:
Step 1: Tools and Supplies
Tools
screw driver
wrench
file
Nerf mavric
Nerf whistle darts
air soft BB's
spring
Step 2: More Power!
This step will show your how to super power the Nerf gun.
First. open up the case, by unscrewing with the screw driver.
Second. detach the top piston spring, then take out the second 1"in spring and place inside the larger spring, make sure it only sticks about one fourth the way, when lined up with other spring, if not use the wire cutters to cut the right about off.
Third. Take the wrench, clamp the spring and push the way that the spring goes until it gits large enough to fit the spring couple.
Fourth. shove the spring back in place and make sure it fits and will lock in place when cocked.
Step 3: Restrictions!
unfortunately every Nerf gun has restrictions, however, you can take them off, by following this step
First. open up the chamber that holds the Nerf darts, and carefully pry it open with a screw driver and watch all the little wimpy springs and forks fall out, once they are all gone just put the end back on the chamber.
Step 4: WARNING!
Somewhere in this mix of moding your Nerf gun, you may have lost a little spring that goes to the trigger,this can be replaced my cracking open a mechanical pencil or pen and sizing the spring to fit the triggers couple. AND WORKS BETTER THAN ORIGNAL
Step 5: Air Soft Dart Mod
This step will show you how to mod a Nerf dart to perfection,
First. get 1-4 air soft BB's and slide them in to the small hole in the tip of the whistle dart. and walla!
The dart now is vary hard, and painfull
The second mod!
Take a air soft BB and place it in the hole in the END of the dart and it will now launch when fired
The second mod!
Step 6: PAINT
I painted it
