Introduction: Nunchuck Mouse
ever wanted to use a nunchuck as a mouse?
all you need is:
a wiimote
a bluetooth adapter
bluesolei
glovepie
a nunchuck.
all you need is:
a wiimote
a bluetooth adapter
bluesolei
glovepie
a nunchuck.
Step 1: Connecting...
take the wiimote battery cover off and press and hold the sync button(red) under the cover. click the sun on bluesolei, and wait for nintendo cnt 01 to show up click the wiimote.. then click the mouse icon when its got a square around it.
Step 2: Programming Glovepie
glovepie must be programmed with the following script:
// Mouse Control Script by marinos35
// filename: miiseSNC.pie
// Version BETA2
// http://WiiMoveU.GooglePages.com
// Hide/Show GlovePIE window by double-clicking the Home button
if var.run == FALSE then
var.run = TRUE
HidePie
var.hidden = TRUE
endif
if ((DoubleClicked(Wiimote.Home) and Wiimote.HasClassic == FALSE) or DoubleClicked(Home) or DoubleClicked(Wiimote.Classic.Home)) and var.hidden then
ShowPie
var.hidden = FALSE
elseif ((DoubleClicked(Wiimote.Home) and Wiimote.HasClassic == FALSE) or DoubleClicked(Home) or DoubleClicked(Wiimote.Classic.Home)) and var.hidden == FALSE then
HidePie
var.hidden = TRUE
endif
// Home button enables and disables the buttons. Function similar to the Lock Key
var.home = SingleClicked(Wiimote.Home)
If var.home and var.on then
var.on = FALSE
elseif var.home and var.on = FALSE then
var.on = TRUE
endif
// Keys for Wiimote
If var.on then
mouse.x = (2 - Wiimote.dot1x / 1023 - Wiimote.dot2x / 1023)/2
mouse.y = (Wiimote.dot1y / 1023 + Wiimote.dot2y / 1023)/2
endif
Mouse.LeftButton = Wiimote.A
Mouse.RightButton = Wiimote.B
Up = Wiimote.Up
Down = Wiimote.Down
Left = Wiimote.Left
Right = Wiimote.Right
// Keys for Nunchuk
var.joyfix = 5 / 100
Mouse.LeftButton = Wiimote.Nunchuk.CButton // C = left mouse click
Mouse.RightButton = Wiimote.Nunchuk.ZButton // Z = right mouse click
if (Wiimote.Nunchuk.JoyX > var.joyfix or Wiimote.Nunchuk.JoyX < -var.joyfix) then mouse.x = mouse.x + Wiimote.Nunchuk.JoyX/50 // {Analog is used
if (Wiimote.Nunchuk.JoyY > var.joyfix or Wiimote.Nunchuk.JoyY < -var.joyfix) then mouse.y = mouse.y + Wiimote.Nunchuk.JoyY/50 // for mouse movement}
// Keys for Classic Controller
Mouse.RightButton = Wiimote.Classic.ZL // ZL = right mouse click
Mouse.LeftButton = Wiimote.Classic.L // L = left mouse click
if (Wiimote.Classic.Joy1X > var.joyfix or Wiimote.Classic.Joy1X < -var.joyfix) then mouse.x = mouse.x + Wiimote.Classic.Joy1X/50 // {Left analog is used
if (Wiimote.Classic.Joy1Y > var.joyfix or Wiimote.Classic.Joy1Y < -var.joyfix) then mouse.y = mouse.y + Wiimote.Classic.Joy1Y/50 // for mouse movement}
// Version BETA2
var.run = TRUE
HidePie
var.hidden = TRUE
endif
ShowPie
var.hidden = FALSE
HidePie
var.hidden = TRUE
endif
var.on = FALSE
var.on = TRUE
endif
// Keys for Wiimote
If var.on then
endif
Up = Wiimote.Up
Down = Wiimote.Down
Left = Wiimote.Left
// Keys for Nunchuk
Step 3: All Done!
ok! click run and you are ready. insert the nunchuck, and start playin around wit it!
