Introduction: Organized Glove Box
Step 1: Inspecting the Space
Step 2: Template/ Tracing/tooling
so I didn't really know how to get the shape so i made a template with pieces of cardboard.
- you will need:
- skill saw
- 1/4 of an inch plywood
- safety glasses!!!
- an idea of what you want it to look like or hold
that is it!
you need to make a template, then you need to trace it on the wood you will use. cut it out with the skill saw. (you may need to revise it later as you cut and test the pieces )
Step 3: Example of Shape/assembling
so i decided to use only two side and not a middle piece you can do what ever your heart decideds.
for quick disassembling I decided to make notches in the wood also taking away using glue and hardware.
I had to cut one if the side pieces to clear a pipe so it could close. but start of with your main shape then revise if needed (measure twice cut once!) I did this all using a skill saw.
Step 4: All Done! But Wait One More Thing!
so as you can see it fits but I had to fix the shelve because once it got towards the back it started to get skinnier. so I cut it at a slight angle from the little tab. but yours may be different.
so that is it I hope you enjoy it, it will make it less frustrating when you get pulled over im sure! lol ;)
