Introduction: Pallet Herb Planter
hey hope you enjoy the planter i made if there are any problems tell me and ill try to fix them!
Step 1: Whats Needed
get a two to three pallets and then disassemble them. your going to need four long boards and nine smaller boards.
Step 2: Making the Pieces
cut the nine small boards in half then take three of the cut in half boards and cut them in half again, take five of the boards and two of the really small boards and put them together like in the second picture.
Step 3: Assembling Box
take two of the boards and put them one on top of the other, in the middle place a metal plate and put screws in the two sides of it like shown above that is a side of your box so make five more.
Step 4: Assembling Box
take two of the short boards and one of the longer boards, take the longer board and screw two brackets in the ends then screw the brackets in two the other shorter boards like in the pictures.
Step 5: Finishing the Box
take the item from the last step and the item from the step before that and screw them together it should look like the picture.
Step 6: Finishing the Box
flip the box over and drill holes in it so water can escape just three or four.
Step 7: Finishing the Box
on the bottom of the boxes put a layer of cloth or fabric like in the picture make two more boxes and move on to the next step.
Step 8: The Planter
take the four long boards screw them together to make two long and thick boards.
Step 9: The Planter
at the end of each box put a dot, make sure the dot is the same on every box.
Step 10: Finishing the Planter
take the three boxes and put them in between the longer boards and screw them together try to screw in the dot you placed last step
Step 11: Finished!
turn the boxes upright and fill the boxes with dirt and plant your plants YOUR DONE!
