Introduction: Pocket Crossbow
This is,as said, a crossbow small enough to fit in most pockets.
for cocktail sticks when made correctly, i avaraged the height of a house fired upward and
horizontal firing i'd say the length of an avarage garden
Use anything for ammo you wish, cocktail sticks were what was available at the time i made this
above all. have fun. just dont poke out any eyes
Step 1: Deciding
first, i need to say, i am not responsible for what you do with the finished product. However i havent even tested it on humans, so if you do, and it causes harm, use it responsibly.
Okay first things>
1.Decide body width and thickness. i was 1 inch wide, and around 3/4 inch thick.
2. decide on finish: i went for duct tape, as it was available.
gather the following.
cardboard or a piece of wood for the body
Paperclips> preferably the bigger ones.
2 elastic bands, or 1 bigger one
pliers, try to have thin tipped pliers, to make it easier to bend the tips or the paperclips
scissors
duct tape
a few( i mean loads, they tend to go blunt, or go lost) cocktail sticks or small kebab sticks
Okay first things>
scissors
duct tape
Step 2: Building the Bow
1st, cut out as many bits of cardboard (same length/width) laying them on top of each other until you get the thickness you want.
Same if you are using a block of wood, you just cut to size.
2nd. straighten the paperclip, and tape it to one of the tips of the body, tape it tight!! i mean the edge of the body, not on top!! important!!
3rd.take the elastic bands, quite small ones are best, and loop one through the other, take the pliers and bend the tips of the clip outward, place one elastic band and squeeze it shut, do this at the other end,and thats that.
4rth. tape a small bit around the knot of the bands, this helps it push the ammo. then cut another piece of cardboard, and make it square, then tape it onto the body, but underneath it. this makes it easier to hold, and also counts for a place to keep ammo.
5th pull back the elastic band at the place you taped it, the paperclip should bend inwards, thats it shaped, next on with the ammo
Step 3: Ammo
cut three slivers of tape, about 1.5 cm in length, and 0.5 cm in breadth, and make the cocktail stick more aerodynamic, by triangulating the slivers, this is hard to descibe, but if you know how to make real sized arrows you know what im talking about.
thats you, just rest the ammo on the body pull back the band and let go, aiming takes a bit of learnng.
try and experiment on where abouts on the body the ammo goes, at the end, far back, in the middle, who knows try it. and be sure to comment on any adjustments you make, so together we can make the ultimate pocket crossbow. of course if its the kebab sticks ure using, then ull have to place it one way only
some tips for u
try making the body from wood, or metal, if metal you could weld the paperclip to the egde.
try using other materials for the paperclip, a kebab stick probably would work, considering the success of the kebab stick bow.
and thats that folks.
some tips for u
