Pocket Sized Alcohol Stove
Intro: Pocket Sized Alcohol Stove
This is a pocket sized alcohol stove for the survival kit i'm working on.
It is really small, yet a good alcohol stove. It has no moving parts and it's made from 2 components, being very strong and durable.
The materials are:
a gas stove's tap's mount piece,
an old lamp,
some wire,
and, of course, the alcohol.
To assemble it just remove all the lamp's socket glass except the bottom black glass wich holds the contact, put it in the stove's piece and secure it with wire. To use it just put the pan on the stove, fill the lamp's socket with alcohol and start it up.
The materials are:
an old lamp,
some wire,
10 Comments
stevec038 11 years ago
tgferreira184 11 years ago
The first is the type of stove and the second is the look under the silver metal.
In the second you can see the piece with the tap mounted (the part which looks like a + and in the other end a pipe to the burner. In the middle is the part we want.
Steve
mkmangold 7 years ago
Zenstoves for sure. Zelph builds the Mangold Mamba which I inspired.
It is a syringe with a piece of stripped bike's brake hose.
to use it you refill it with alcohol, pass the hose in the stove's screw hole and empty the syringe in the lightbulb.
An advice if you are going to make one:
Use a bigger lightbulb than mine becouse mine has fuel for 2.5 minutes and if you dont hurry putting some more on it the water will cool and will not boil.
What other fuels are you talking about?
sergio mendes 11 years ago
By the way I'm from Portugal.
