Introduction: Pocket Sized Tool Box
This is my pocket sized tool box. It has every thing I need to fix things outside my home and can be used as a survival kit. It contains tools like small screw drivers, small marker, and measuring tape Hmmm what else might I need? I need a tape , pliers , wire cutter , lighter , hot glue and solder iron ...etc.
The tape :
I get a small pen tube so I roll a tape on it.
Pliers :
This is something for nails but you can use it like pliers or diagonal or wire cutter.
Cutter knife:
I took a lighter to melt the hot glue and stick with.
For solder I took a solder wire and melt it and solder with.
I collect tools in a cardboard box and here I have it in a pocket sized tool box.
To Hot glue and soldering with a lighter
I took a lighter and a solder wire for soldering with and a small hot glue gun stick to stick it with.
It works very goood.
cutter knife: It was a old cutter knife and i cut it into half and make it look nice!
and i take a lighter to melt the hot glue and stick with
and for solder i take a solder wire and melt it and solder with
and i collect tools in a cardboard box and here i have it a pocket sized tool box
Step 1: Hot Glue and Soldering With a Lighter
Step 2: Measuring Tape
Step 3: The Electrical Tape
This is my home made electrical tape you can make it from a piece of plastic pen and electrical tape.
take the plastic pen and roll it on the electrical tape.
Step 4: Other Tools
Pliers : This is a metal thing for nails but you can use it like pliers or diagonal or wire cutter.
Cutter knife : The cutter knife was too long so I shortened it.
