Introduction: Protable Power Bank
this is an easy project to make an 5v portable power bank for just 2$!
Step 1: Parts
The parts you will need for this project is:
* 3x AAA batteries
* 3x AAA battery holder
* 5v step-up
* SPST switch
* Enclosure
* Hot glue
Step 2: Cut the Wires
Cut the wires from the battery holder to the size you want them to be.
Step 3: The Switch
My switch was a little bitt to big so i had to bend the two mounting plates.
Step 4: Soldering
Solder the ground wire to the 5v step-up module and solder the switch to the positive wire, take an red wire that you cut off from the battery holder and solder it to the other pin on the switch and solder the other and of the wire to the positive connection on the 5v step-up module. When you are done whit the soldering remember to test it.
Step 5: Gluing
Glue the module to the battery holder whit hot glue or superglue, I used superglue first but the module fell off the battery holder when i moved it later so I used hot glue instead. NOTE: never ever glue an switch whit superglue! The glue always finds an way to get inside the switch :P
Step 6: Enclosure
Make an nice enclosure for your project! I really want an 3D printer but I don't have one so i made my enclosure out of some hard paper I had.
THANKS FOR VIWING!
If you liked my project than check out my cannel for more cool projects and if you have made one of my projects or have any questions please post it in the comments. :)
