Introduction: Pump Action Dart Shooting Air Gun
This is how to make an air gun which is a single shot (shoots 1 dart) which uses PUMP action, and looks like a shotgun it shoots about twice as far a my blowgun i have made (u can find it on this site) which is about 100m and onwards I used the air to shoot the air gun from a compresser in my shed and that uses stuff all pressure so you can imagen how far it would shoot with an air chamber (currently under construction)
also it has a trigger and sights
Step 1: Materials
What you need -- I HAVENT ADDED THE AIR CHAMBER IN YET --
bolt action design (on this site, look in search for BOLT ACTION BLOWGUN) this can be changed into pump action if you want.
curtain rod the same size as the bolt action 2 PVC joiners to connect the curtain rod to the bolt action/pump action and the bolt action to the trigger and a piece of wood for a grip it u want
you need a air sprayer you can buy these from hardware stors cheap ( they connect to hoses and spray air out, used in workshops to clean stuff, air sprayer fittings they usuall come with the sprayer or they might not LOOK AT PIC IF YOU DONT GET IT
Step 2: Putting It Together
now just put the pieces together
and use a strong glue to bond the PVC joints to connect the bolt action to the curtain rod and to the sprayer
--- COMING SOON ---
I WILL SHOW YOU HOW TO MAKE THE PUMP ACTION DESIGN IN A SEPERATE INSTRUCTABLE
NOTE : u need to seal everything as good as possable so no air leaks out
--- COMING SOON ---
Step 3: Making
FOLLOW THE PICS
USE JOINERS WHERE THE ARROWS ARE POINTING I HAVENT DRAWN THEM IN, SORRY
Step 4: Still Making
refer to pic
what it should look like but good, this paint drawing sucks
Step 5: MORE PICS
SEE PICS
HERE the pump actin is closed NOTE THE WHITE PVC THIS IS A JOINER
you can give it a camo job with paint or cloth or whatever
HAVE FUN AND DONT KILLLLL STUFF
leave messages if you want more infomation or EMAIL ME Rambohunt@gmail.com
