Introduction: Pvc "TOOTOPHONE" -- a Musical Reed Instrument
This is the first of an evolving series of tootophones that I have made. I leave it up for historical interest, but suggest you try the "Tiny Tootophone" for the basic mouthpiece, and the "Tootophone Sax and Trumpet" for some interesting body variations using x-ray film. This PVC design is not even in my "top ten" list any more. My latest tootophones have only one fingering hole.
The body of this tootophone is made of 1/2" CPVC pipe, which is used for hot water plumbing and is of a smaller diameter than 1/2" PVC pipe.
The tootophone is similar to a soprano recorder in terms of size and finger spacing. The mouthpiece is heat formed to make it a little narrower than the CPVC pipe.
The reed is cut from a piece of plastic from an old flat screen monitor I disassembled. Just about any semi-stiff, clear packaging plastic will work to make a reed that vibrates.
I have always liked the idea of playing saxophone, but found the bamboo reeds to be frustrating to get sounds out of. For some reason, these plastic reeds are a lot easier to blow. Being less frustrating to blow, the tootophone is more fun to play, at least for a beginner. Being more fun to play, I play more, and that's what it's all about. Tootophones are fun to play.
Figure maybe a dollar in material and many hours playing around. This is very cost effective entertainment.
Be sure to check out the audio files at the end, to hear what the tootophone sounds like.
Step 1: Finger Hole Spacing
The distances between holes are copied from a soprano recorder. The holes are not all placed on the center line down the pipe. Since some fingers are longer than others, the holes have a little sideways displacement to increase comfort while playing. When penciling hole locations, hold the pipe as you would while playing it to find and mark a comfortable side displacement for each finger hole.
There are seven finger holes and one hole for the thumb on the opposite side of the body -- the same as on a recorder.
On a recorder, double holes at #6 and #7 help get half tones. I elongate my holes and just half-close them when needed.
Step 2: Shaping the Finger Holes
After drilling the appropriately sized holes, I use some sandpaper wrapped around a piece of 5/8" wooden dowel material to modify the hole. That makes it easier to seal the hole with one's finger, reducing unwanted squawking sounds.
In the raw hole, there is a pocket of air inside the hole underneath the finger. I like to bring the finger down a little lower, thus reducing the pocket of air and turbulence inside the tootophone body. It probably results in a cleaner sound.
I made a special tool to get inside the drilled finger holes and scrape the burrs from inside of the tootophone body. (A tiny knife with a bent end, made of stainless steel welding rod.) That, too, reduces turbulence and makes the instrument easier to play.
Step 3: Safety While Heating PVC
We love plastics for what they do for us, but plastic manufacture and decay tend to pollute the environment and negatively affect our health.
Vinyl Chloride, one of the components of PVC, is carcinogenic. When it is locked up in the polymer, however, it is much safer to be around. In my years of experience working with PVC, I have not noticed any adverse effects on my health from being around it.
Always work in areas with good ventilation. If you do get caught in a cloud of smoke, hold your breath and move to clean air.
When heating PVC with a gas stove or propane torch, try not to let it burn. Smoke from burning PVC is bad. With experience one burns it less and less. Don't panic the first time you do burn some. It scorches, but doesn't immediately burst into flame. Move the material away from the flame and try again. Don't breathe the smoke. Smoke avoidance comes naturally for most people.
While heating PVC over a gas flame, keep the plastic an appropriate distance from the flame to avoid scorching the surface before the inside can warm up. It takes time for heat to travel to the center of the material being heated.
Keep the plastic moving, and keep an eye on the state of the plastic. When heated, the PVC material is flexible, like leather. Beyond this stage, you risk scorching it.
A word from James, the plastic engineer -- "Just a word of warning, PVC can handle some high heats but if it catches fire, you wont be able to put it out, it does not need oxygen to burn so don't do this inside".
I do work inside, but my house is made of cement and has good ventilation. MAKE SURE THAT YOU HAVE GOOD VENTILATION. PLAY WITH FIRE -- CAREFULLY.
Step 4: Heat Forming the Mouthpiece
One can make a mouthpiece that works just by cutting a piece of pipe at an angle, giving the straight cut a little curvature with a file, and putting on a reed. In pursuit of the ideal mouthpiece, my preferences have led me to doing some heat forming first to narrow the width of the mouthpiece and reed a little. That allows me to make reeds that are long and narrow, which I find easier to control, especially for high notes.
I use a wood forming tool, which fits inside the pipe to help give proper form to the soft plastic.
As with any plastic heat forming, try to avoid burning the material, which creates toxic gasses. See the safety warning step.
Step 5: Shaping the Mouthpiece
The reed is held down to the cut surface by one's lower lip. If the cut surface is straight, the part of the reed that is supposed to vibrate will touch that surface and have no room to vibrate. Thus, the cut line needs to be modified to have a slight but continuous curve to it so that no matter where your lip presses down on the reed, like a tangent line on a circle, the tip of the reed will still be able to vibrate.
Water from spittle and condensation are hard to avoid. When water gets between the reed and the contact surface of the mouthpiece, it can stick the reed to the mouthpiece and stop it from vibrating. That kills the sound.
To minimize that problem, minimize the contact area between the reed and mouthpiece by filing the plastic down some.
Step 6: Forming the Reed
Semi-stiff clear plastic that is used in packaging products can work as reed material. What I am using now was salvaged from a junked flat screen monitor.
Hold the mouthpiece up against the plastic so that you can see through the plastic and mark the contours of the contact area with a fine point marking pen.
I mark and cut just the area that is going to be taped to the mouthpiece. I cut the rest of the reed after it is taped down. Try to cut it close to the mouthpiece tight so excess material won't irritate your tongue or lip. Use fine sandpaper on the edge of the reed to round any sharpness that might irritate your lip.
Step 7: Heat Forming the Joint Connector
You need to connect the mouthpiece to the body with a connector sleeve. I make the connector out of 1/2" PVC pipe that is 1 1/2" long. It needs to be widened a little bit for the CPVC pipe to fit, so I heat it and then push a piece of the CPVC pipe into it to stretch it out a little. To heat it, I hold it with needle nose pliers over a propane torch flame, being careful to not burn it. After forming, cool it off by dipping it into water, and then tap the connector off of the pipe with a block of wood and a hammer if you can't get it off by hand.
Trim with a knife, or use a file to round off any rough edges.
Step 8: Reed Protector Cap
The reed is delicate and you want to protect it when not being used, especially in travel.
The cap is made of 3/4" PVC. It has four slits, making four fingers which flex outward to hold the tootophone by the joint connector sleeve.
Step 9: Playing Tips
The tootophone is a very intuitively played instrument. You can get the same notes with different lip and finger positions. It is like riding a horse, instead of driving a car.
Playing the tootophone is a lot like singing, only silently, without using the vocal cords. Think of how your Adam's apple goes up and down as you sing high or low notes. Also, the volume of air inside your mouth changes as your tongue moves.
Changing your lip position also affects things, and you have to clamp down tighter on the reed for the higher notes. Allow the whole reed to vibrate for the lowest notes. Shorten the length by moving toward the tip of the reed with your lip. You can get a range of high and low notes without even using your fingers.
When you get into fingering, it helps to be familiar with standard recorder fingering. "Singing" the note while fingering it at the same time sometimes produces a cleaner note than singing alone. Also, you can do rapid effects with the fingers that you can't do with mouth action alone.
I usually bleed a little air off to the side of the mouthpiece while playing. It helps me control my breathing so I don't get tired out from playing and helps me stabilize long held notes, also.
If you are careful to not damage the reed, you can occasionally bend it out a little and clean off saliva build-up with your fingers. Saliva can stick the reed down and kill the sound.
This link will take you to some recorder fingering information, which might give you some fingering hints. http://en.wikipedia.org/wiki/Recorder
Step 10: Sample "music"
Click the MP3 file below to hear what a tootophone can do.
(The digital collage is part of my "Party After The Concert".)
38 Comments
8 years ago
i didnt understand how long,what possition,how big that hole and how to calculate it...please teach me...i think you can teach me how to put that holes in vid....i think that way can make me more understand
This was my earliest tootophone post. I leave it up mostly as evidence of the instrument's evolution. I don't recommend you spend your time duplicating it.The hole sizes and spacing are the same as a soprano recorder has, if you really want to make it. I don't have a video camera to show you.
The more evolved tootophones are much more interesting musically. I suggest you search for "tiny tootophone" or "silicone rubber tootophone mouthpiece". Start with the tiny tootophone, made from a 10 cent insulin syringe to learn the basics. Once you have made a few and get a feel for how changes in the curve relate to changes in the sound, move on to the silicone rubber mouthpiece, which is the best I have to offer at the moment. javascript:;
8 years ago on Step 1
what is the equipment needed ?
Reply 8 years ago on Step 1
Mostly a drill, bits, and an X-acto knife.
13 years ago on Introduction
Old credit cards, debit cards, and gift cards make great reeds.
I made two of these: one from 3/4" PVC and one from 1" PVC. They sound great, but the finger holes start to get a little far apart for a comfortable reach as the tube gets bigger. A larger mouthpiece will also yield a slower vibration and, therefore, lower note. It might be worth trying to graft a 3/4" PVC mouthpiece onto a 1/2" tooter. The photo is of the 3/4" version. The multitude of holes is for experimentation purposes.
Reply 13 years ago on Introduction
Reply 11 years ago on Introduction
That looks impossible to play, that thing has 15 holes
Reply 12 years ago on Introduction
Too many holes! How can you cover them all? :O
I should note: You can make a bell on the end by heating the end (per thinkingstein's instructions in Step 3), then pushing the soft end over a cone shape. I used a funnel.
can you fit a real cane instrument reed on that
11 years ago on Step 10
Sounds halfway between a saxophone and a kazoo
Hey Thinkenstein!
Your reed instrument has pushed me to make a saxophone. I have made a mouthpiece that looks like yours and it gives a good, saxophony sound. But, unfortunately, no matter how long my pvc tube is, it gives the same high pitch. I made the mouthpiece-fingerholetube connector from a piece of cardboard and taped it with electrical tape (all over the cardboard). Did I do anything wrong?
Please, help me.
Hi Ssjcell1. This was one of my first tootophones. It was always a bit out of control. I suggest you forget this and move on to my "tiny tootophone" instructable, and the saxtooter and trumpetooter instructable. The saxtooter uses the tiny tootophone mouthpiece, made from an insulin syringe (about 15 cents to make), uses a silicone rubber reed, and sounds reasonably like a sax. The body is made of x-ray film, free from the x-ray lab at the hospital.
Hope that helps.
What's the range on this?
My tootophones have evolved quite a bit since this one. I never play this one any more. My favorites are of the tiny tootophone variety. https://www.instructables.com/id/Tiny-Tootophone
They get a couple octaves with no problem.
could you use a saxophone reed on it.
My dad said he had one I could borrow.
Search for "Tiny Tootophone" to get my favorite tootophone design. They have evolved over time, and this PVC design was one of the first.
Regular reeds are stiffer than the plastic and rubber I use. Softer reeds are easier to blow. Tootophones have gotten easier to play the smaller they have gotten. Some of my favorite reeds are made of silicone rubber, sometimes mixed with filler powders, like Cab-o-sil, a powder used as filler in epoxy clay, I believe. Others are made with x-ray film plastic, after scrubbing off the image.
Anyway, I suggest you skip ahead to the Tiny Tootophone, which is made of an insulin syringe and costs about 15 cents to make.
Have fun!
I am now the proud owner of my own Tootophone (thank you Thinkenstein) and I just love it, it is really easy to get the hang of, and my dogs love it too - everyone should make one because it is so easy to stick in your pocket and take everywhere with you. The sound just makes everyone happy.
Happy is good. Thanks.
I would very much like to make one using some old venetian blinds strips to make the reeds as I have some laying around. or do you think they would be too stiff to make an effective reed?
