Introduction: Quick and Easy Marbled Paper
After recently receiving a great gift from my aunt, I had to go about making her a thank you card. so I decided on making her a card make out of marbled paper.
so first off, what is paper marbling?
paper marbling is a method that you can use to decorate paper or fabric. it gets it's name because the finished product looks a lot like the rock, marble. the process involves floating ink on top of water, then laying a piece of paper on top of the water. then what you end up with is marbled paper
*note*
I am not a professional paper marbler(are there professional paper marblers?), these instructions are just simply how you can do it at home.
*note*
Step 1: What You'll Need
You don't need a lot to marble paper. most, if not all of these things you will already have in you house. so here's the list.
- A large tray or pan, don't use that you use for food unless you are willing to clean it thoroughly. I recommend using one of those aluminum ones that you can get at the dollar store.
- Marbling ink. this stuff can be expensive, and I didn't have any on hand so I used India ink.
- A piece of paper or card to marble.
- Water.
- a toothpick to swirl the ink.
- a dip pen ( this one is optional)
Step 2: Starting the Marble
After you have assembled you materials, you can begin.
First, dip your pen into the ink. get a good amount on there. Then you lightly touch the pen onto the surface of the water. the ink will spread out in circles. do this a few times until you think you have enough ink floating on the water.
Step 3: Swirl the Ink
This is my favorite part! take your tooth pick, comb, or whatever you want so swirl you ink with and mix it up. now don't just do this step haphazardly! don't stir it like a spoon because it will turn all of the water will just turn a sickening gray. you have to experiment with this step, try drawing your toothpick from side to side, move it in a spiral, whatever you want.
Step 4: Get It on Your Paper.
okay, now you take the piece of paper or card and lay it on top of the water. let it sit there for a couple of seconds, and then you can take the paper off.
After that lay you paper somewhere sunny dry, and admire your work!
*note*
One thing I have found is that when the paper dries it will warp. you can solve that by ironing it! just be careful not to burn it
*note*
Step 5: Admire
Now use the paper for whatever you want! you could use it in book binding, for stationary, or whatever else you can imagine. I made mine into a card, and sent it to my aunt (she loved it!).
